BT.com
Wishlist
Zyxel LTE7410-A214 LTE Outdoor IAD
Delivery
Standard Due date unavailable
As mobile devices such as smart phones and tablets consume more wireless broadband, the crowded bandwidth has become a big issue to operators. Mobile broadband is a better solution than fixed-line broadband for its lower investment and faster deployment. However, since fixedline has been the major broadband infrastructure in most places of the world for a long time, people are already using fixed-line for broadband Internet connection in most cases. Migrating from fixed-line to mobile broadband may need extensive evaluation, however adding mobile broadband as a backup for better performance or stability could be an easier decision. The ZyXEL LTE7400 Series comes with the critical features "the second WAN" needs - flexible routing mode with both bridge and router function, high-gain antenna for better signal and performance as well as outdoor design with robust IP67 hardware for harsh environments. No matter you have a router device or not, the LTE7400 Series can be easily deployed and integrated into your existing environment. You can set LTE as your main connection, or use LTE as a backup when performance of the main connection drops. The LTE7400 Series is good for any venue like suburban areas, public locations, homes and offices. Enjoy LTE technology with minimum effort with the LTE7400 Series.
Zyxel LTE7410-A214 - router - WWAN
Router - wireless cellular modem
Cellular Protocol
LTE
NAT sessions: 4096
Network / Transport Protocol
L2TP
Routing Protocol
Static IP routing, GRE
Remote Management Protocol
Telnet, HTTP, TR-069
VoIP Functionality
VoIP phone adapter
VoIP Protocols
SIP v2, RTCP, RTP, SDP
Telephony Interfaces
1 phone (FXS)
NAT support, power over Ethernet (PoE), IPv6 support, VPN passthrough, firmware upgradable, Quality of Service (QoS), DHCP server, IPv4 support, DHCP relay, DHCP client, Firmware Over-the-Air (FOTA)
31.3 cm x 36.3 cm x 11.5 cm
2.12 kg
United Kingdom
2 years warranty
Router
Wireless, wired
NAT sessions: 4096
L2TP
Routing Protocol
FCC, RoHS, IP67
Communications
Wireless cellular modem
Cellular Protocol
LTE
Max Transfer Rate
150 Mbps
IP Telephony
VoIP Functionality
VoIP phone adapter
VoIP Protocols
1 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), silence suppression, DTMF generation/detection, dynamic jitter buffer, packet loss concealment (PLC)
LAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , Phone line: 1 x FXS - RJ-11
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
Internal
Gain Level
10 dBi
16 Watt
Mounting Kit
Included
United Kingdom
31.3 cm
36.3 cm
11.5 cm
2.12 kg
-40 °C
60 °C
5 - 95% (non-condensing)
Scroll to top
