BT.com
Wishlist
Zyxel GS2210-8 8 port Gigabit L2 Managed Switch - Fanless
Zyxel GS2210-8 8 port Gigabit L2...
£135.32
£135.32
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL GS2210 Series are fully featured Layer 2 Gigabit access switches designed to meet these converged data, video and voice networking challenges. The Series comes with a combination of GbE RJ-45, GbE SFP and GbE combo (RJ-45/SFP) connectivity. The PoE models comply with the IEEE 802.3af PoE and 802.3at PoE Plus standards and provide a high PoE power budget. With rich traffic shaping, network isolation, and security features, the GS2210 Series is the perfect L2 access switch solution for converged data, video and voice networking.
ZyXEL GS2210-8 - switch - 8 ports - Managed - rack-mountable, wall-mountable
Switch - 8 ports - Managed - stackable
Enclosure Type
Rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 20 Gbps , Forwarding performance: 15 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, traffic shaping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, IPv4 support, fanless, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, ErrDisable Recovery, ZyXEL Discovery Protocol (ZDP), ZyXEL One Network (ZON), IGMP filtering, IGMP throttling
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V ( 50/60 Hz )
25 cm x 15 cm x 4.4 cm
1.425 kg
United Kingdom
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, link/activity
10 x 1000Base-T - RJ-45 , 2 x - SFP , 1 x serial (RS-232) - DB-9
Internal power supply
9.45 Watt
Rack mount kit, wall mounting kit
MTBF
1,382,029.73 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
United Kingdom
25 cm
15 cm
4.4 cm
1.425 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
Scroll to top
