BT.com
Wishlist
Zyxel GS2210-24HP 24 port Gigabit L2 managed PoE+ switch  37
Zyxel GS2210-24HP 24 port Gigabit...
£595.50
£595.50
Add to wishlist
Delivery
Standard 1-3 working days
Incorporating data, video and voice communications into a single IP network provides more effective communications, centralized IT management, and lower overall deployment cost for the entire organization. This is why an increasing amount of businesses, educational institutions, and hotels are adopting such IP-based services as VoIP, video conferencing, IP surveillance, and IPTV. Yet such converged deployments pose many challenges to the IP network. IT staff need to ensure consistent performance for critical applications, provide sufficient isolation and network security, and shape network traffic to meet the demands of diverse deployments.
The ZyXEL GS2210 series are fully featured Layer 2 gigabit access switches designed to meet these converged data, video and voice networking challenges. The GS2210 series supports ZON utility and ZyXEL one network inter-device features that make network setup and maintenance easier, more efficient, and more unified than ever before. With rich traffic shaping, network isolation, and security features, the GS2210 series is the perfect L2 access switch solution for converged data, video and voice networking.
Zyxel GS2210-24HP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 56 Gbps , Forwarding performance: 41.67 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, traffic shaping, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, NTP server, IP-MAC binding, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, port isolation, Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, ErrDisable Recovery, ZyXEL Discovery Protocol (ZDP), ZyXEL One Network (ZON), IGMP filtering, IGMP throttling
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 33 cm x 4.45 cm
4.79 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Power, system, link/activity
24 x 1000Base-T - RJ-45 - PoE+ - 30 W , 4 x - SFP , 1 x serial (RS-232) - DB-9 , 4 x 1000Base-T - RJ-45
Internal power supply
476.7 Watt
MTBF
133,062.5 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A, BSMI ENC
United Kingdom
44 cm
33 cm
4.45 cm
4.79 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
Scroll to top
