BT.com
Wishlist
Zyxel GS2200-8 8-port Gigabit L2 Managed Switch
Zyxel GS2200-8 8-port Gigabit L2...
£131.06
£131.06
Add to wishlist
Delivery
Standard Due date unavailable
The GS2200-8 series is ideal for secure 100BASE and Gigabit connectivity, and it offers access security, advanced prioritization and traffic-monitoring capabilities. The GS2200 series is easy to use and manage for applications needed to support business operations as well as to increase productivity. The CPU protection feature can greatly reduce the likelihood of malfunctions. ZyXEL iStacking clustering management technology can manage devices across different floors and routing domains to locate other iStacking-capable switches in the same management cluster. This allows administrators to manage up to 24 switches with one single IP address. ZyXEL iStacking greatly reduces operating costs and offers more flexible maintenance of ZyXEL Switches. IT staff can opt for the Web or command line interface to suit their needs, and even encrypt their instructions with SSHv1/v2 and SSL. With these sophisticated functionalities, the IT staff is empowered to build a highly secure and efficient corporate network with minimum effort.
Zyxel GS2200-8 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 20 Gbps
Virtual interfaces (VLANs): 1024
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, port mirroring, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), bandwidth control, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ)
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
25 cm x 15 cm x 4.4 cm
1.34 kg
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
448 KB
Status Indicators
Port status, link activity, power, system
10 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x SFP (mini-GBIC) , 1 x serial (RS-232) - DB-9
Internal power supply
12.3 Watt
BSMI, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
United Kingdom
25 cm
15 cm
4.4 cm
1.34 kg
50 °C
10 - 90% (non-condensing)
Other bundles
£131.06
Save on TP Link Smart Plug
Save £2.00
£155.03
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
