BT.com
Wishlist
Zyxel GS1100-16 16 port Gigabit Unmanaged Switch
Zyxel GS1100-16 16 port Gigabit...
£54.64
37 in stock
£54.64
Add to wishlist
Delivery
Standard 3-5 working days
The ZyXEL GS1100-16 is positioned to deliver a solution that requires no switch management for office environments demanding silent operation and green technology. It provides plug-and-play simplicity for high-bandwidth connectivity.
The GS1100-16 is a 16-port 10/100/1000 switch and protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
Zyxel GS-1100-16 - switch - 16 ports
Switch - 16 ports
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Forwarding performance: 23.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Flow control, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
21.5 cm x 13.3 cm x 4.2 cm
1 kg
United Kingdom
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9000 bytes
16 x 1000Base-TX - RJ-45
Internal power supply
6.4 Watt
MTBF
48,385 hours
RoHS, EN 60950-1, FCC Part 15 B Class A, EMC Class A
United Kingdom
21.5 cm
13.3 cm
4.2 cm
1 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
