BT.com
Wishlist
Zyxel GS1100-10HP Unmanaged PoE 8xGigabit, 2xFiber Uplink 120 Watt
Zyxel GS1100-10HP Unmanaged PoE...
£104.13
Hurry, only 2 left in stock!
£104.13
Add to wishlist
Delivery
Standard 1-3 working days
The ZyXEL GS1100 series is the optimal solution for instant Gigabit connectivity in office environments demanding silent operation and better energy efficiency. With power-saving functions, Gigabit Ethernet and a fanless design, the GS1100 series provides Plug and Play simplicity for high-bandwidth network applications. The GS1100 series not only offers Gigabit Ethernet connectivity for advanced network applications, but also power-saving functions for better energy efficiency. Capable of dynamically adjusting power output according to traffic, active links and cable length, the GS1100 series can reduce energy consumption.
Zyxel GS1100-10HP - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.88 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
25 cm x 10.4 cm x 2.7 cm
730 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port status, link activity, power, PoE
8 x 1000Base-T - RJ-45 - PoE+ , 2 x - SFP
156.1 Watt
MTBF
1,000,070 hours
RoHS, IEC 60950-1, EN 60950-1, BSMI CNS 13438, LVD, BSMI CNS 14336-1
United Kingdom
25 cm
10.4 cm
2.7 cm
730 g
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Scroll to top
