BT.com
Wishlist
Zyxel Firewall Appliance 10/100/1000, 8x configurable UTM Bundle
Zyxel Firewall Appliance...
£1,170.27
Hurry, only 1 left in stock!
£1,170.27
Add to wishlist
Delivery
Standard 1-3 working days
More and more people are relying on smart devices and cloud-based applications for business communications. This means that high network availability is critical for business continuity, more Wi-Fi is demanded in the workplace, and traditional regulatory measures for application usage are obsolete. Without an effective solution to control, optimize and block social, productivity and other web applications, SMBs risk losing work productivity and exposing company networks to new web threats.
The ZyXEL USG Advanced Series are Next Generation Firewalls (NGFW) designed to meet the mobility, anti-malware and policy enforcement challenges in SMBs. The integrated WLAN controller offers easy WLAN scalability for the growing demand for Wi-Fi; while WAN and VPN load balancing and failover ensures nonstop business communications. ZyXEL USGs offer industry-leading anti-virus, anti-spam, content filtering and application intelligence technology for effective application optimization and comprehensive network protection.
ZyXEL USG310 - UTM Bundle - security appliance
Security appliance
Bundled Services
1 year AV+IDP, AS, CF
Licence Qty
25 SSL VPN users
Rack-mountable
United Kingdom
Performance
Firewall throughput: 5 Gbps , VPN throughput: 650 Mbps , Intrusion detection and prevention throughput: 450 Mbps , Antivirus throughput: 400 Mbps , Unified Threat Management (UTM) throughput: 400 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 300 , Concurrent sessions: 100000 , Concurrent SSL VPN users: 105 , Virtual interfaces (VLANs): 64 , New sessions: 12000 , Manageable access points: 2 (maximum 18)
43 cm x 25 cm x 4.4 cm
3.3 kg
Security appliance
Bundled Services
43 cm
25 cm
4.4 cm
3.3 kg
United Kingdom
Rack-mountable
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
8 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x console - DB-9
MTBF
560,811.5 hours
BSMI, EN 60950-1, FCC Part 15 A, C-Tick Class A, LVD, EMC Class A
External power adapter
58.5 Watt
Virus definitions update - 1 year , Intrusion definitions update - 1 year , URL Database update - 1 year , Spam filter update - 1 year
Scroll to top
