BT.com
Wishlist
Zyxel Firewall Appliance 10/100/1000, 8x configurable  UTM Bundle
Zyxel Firewall Appliance...
£2,545.64
£2,545.64
Add to wishlist
Delivery
Standard Due date unavailable
As business grows and network expands, more and more users and devices as well as new applications like cloud-based services would join the network. It means that high network availability for sustainable business, more workplace Wi-Fi and up-to-date regulations for application usages are eagerly needed. Without an effective solution to control, optimize or block social and some other Web applications, businesses would risk not only losing productivity but also exposing company network to new threats. The ZyXEL USG Extreme Series are Next Generation Firewalls (NGFW) designed to deliver high availability, anti-malware protection and consolidated policy enforcement for medium-to large-sized businesses and campuses. The ZyXEL USGs provides WAN and VPN load balancing and failover ensures nonstop business communications, while incorporating bestin-breed anti-virus, anti-spam, content filtering and application intelligence technology for effective application optimization and comprehensive network protection.
Zyxel USG1100 - UTM Bundle - security appliance
Security appliance
Bundled Services
1 year AV+IDP, AS, CF
Licence Qty
55 SSL VPN users
Rack-mountable
United Kingdom
Performance
Firewall throughput: 6 Gbps , VPN throughput: 800 Mbps , Intrusion detection and prevention throughput: 550 Mbps , Antivirus throughput: 500 Mbps , Unified Threat Management (UTM) throughput: 500 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 1000 , Concurrent sessions: 300000 , Concurrent SSL VPN users: 255 , Virtual interfaces (VLANs): 128 , New sessions: 12000 , Manageable access points: 2 (maximum 18)
43 cm x 25 cm x 4.4 cm
3.3 kg
Security appliance
Bundled Services
43 cm
25 cm
4.4 cm
3.3 kg
United Kingdom
Rack-mountable
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
8 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x console - DB-9
MTBF
560,811.5 hours
BSMI, EN 60950-1, FCC Part 15 A, C-Tick Class A, LVD, EMC Class A
External power adapter
58.5 Watt
Virus definitions update - 1 year , Intrusion definitions update - 1 year , URL Database update - 1 year , Spam filter update - 1 year
10 - 90% (non-condensing)
Scroll to top
