BT.com
Wishlist
Zyxel ES1100-16P 16-port FE Unmanaged PoE Switch
Zyxel ES1100-16P 16-port FE...
£111.14
12 in stock
£111.14
Add to wishlist
Delivery
Standard 1-3 working days
The environment-aware switch 1100 series - Fast Ethernet offers 10/100M Ethernet speeds critical to the next-generation network applications, and it also provides power-saving functions to reduce energy consumption for lower operating cost.
The switch 1100 series - Fast Ethernet comprises of unmanaged Fast Ethernet switches that provide an inexpensive solution for Fast Ethernet connections to the desktop with outstanding performance. The switch 1100 series - Fast Ethernet is an ideal solution for bandwidth-intensive applications such as high-resolution photo delivery, video/audio streaming and downloading as well as server farm connections.
The full switch 1100 series has been designed to boost your network with better performance and efficiency. With the N-way auto-negotiation function, the switch 1100 series - Fast Ethernet connects the network counterparts with the highest possible data speed and activates the duplex mode automatically.
Unlike shared 10/100 Mbps networks, the switch 1100 series - Fast Ethernet eliminates congestion by providing dedicated bandwidth; and its duplex mode doubles the effective bandwidth by enabling two-way communications. The store-and-forward service brings low latency and error-free packet delivering, while the Plug-and-Play and multiple network protocol compatibility of the switch 1100 series - Fast Ethernet makes installation and management easier and faster than ever.
With embedded rackmount brackets, the desktop size devices can fits into your rack environment easily. No matter how intense your network demand is, the switch 1100 series - Fast Ethernet supports your needs with an affordable and reliable network solution designed especially for small businesses.
Zyxel ES-1100-16P - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE) + 8 x 10/100
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 3.2 Gbps , Forwarding performance: 2.4 Mpps
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Broadcast Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
26.2 cm x 18.4 cm x 4.1 cm
1.7 kg
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Fast Ethernet
Ports
PoE
Performance
8K entries
RAM
160 KB
Status Indicators
Power, PoE, link/activity
8 x 100Base-TX - RJ-45 - PoE , 8 x 100Base-TX - RJ-45
Internal power supply
RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 A
United Kingdom
26.2 cm
18.4 cm
4.1 cm
1.7 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
