BT.com
Wishlist
Zyxel Dual-Radio Access Point
Delivery
Standard Due date unavailable
Ratification of IEEE 802.11n allows the technology to achieve good growth in commercial environments as it helps businesses to cope with challenges from increasingly complicated and bandwidth-hungry applications. In addition to enhancing throughput and coverage, the IEEE 802.11n standard offers the following benefits: elimination of bandwidth contention, future-proof support as well as accommodation for more users and floor space.
To catch up the wave of 802.11n, ZyXEL introduced the enterprise-level NWA3000-N series Access Point (AP) to meet the requirement of the "generation". Designed to meet the requirements of SMB market segment, the NWA3000-N series is ideally suited for advanced service delivery on mission-critical networks.
The ZyXEL NWA-3560-N is a "hybrid" AP that acts as a standalone AP infrastructure or a centralized management structure with controller mode and managed AP. The hybrid feature has full flexibility to deploy secure and reliable WLAN networks. In the initial phase constructing a WLAN, the NWA-3560-N can be configured as a fully functional standalone AP; with more APs installed, the NWA-3560-N can be set to the WLAN controller mode to manage the rest of APs. The scalability is able to manage up to 24 APs and it is also suitable for companies with a staff of 300-500.
In order to eliminate complicated configuration and installation processes, the NWA-3560-N AP provides a variety of features to allow quick network deployments. All ranges of NWA-3560-N APs comes with standard 802.3af or 802.3at PoE support that enables the APs to utilize the existing cabling and receive power from PoE switches. Once installed and powered up, the NWA-3560-N AP automatically discovers the controller AP and join the management group; and secure automatic provisioning is established between the controller AP and the managed APs effortlessly.
Small and medium-sized businesses usually have tighter equipment budgets and limited IT staff. With the NWA-3560-N, the SMBs can take advantage of the flexibility to meet growing needs while building a future-proof office network. More than just WPA/WPA2 personal and enterprise certification, the NWA-3560-N also features an embedded RADIUS server that saves expense and maintenance efforts by eliminating standalone RADIUS servers; the NWA-3560-N also supports device HA to provide stable and reliable connections for non-stop productivity. All indoor units of the NWA-3560-N adopt LSOH material for plenum spaces; in case of fire, the material would produce the least amount of toxic or corrosive smoke to avoid harming people around. With all the considerate design along with business AP features such as multiple SSID, the NWA-3560-N AP is the smart and pragmatic choice for growing SMBs.
ZyXEL NWA-3560-N - radio access point
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 120 Mbps
Manageable access points: 24
Power Over Ethernet (PoE) Supported
PoE
19.8 cm x 13.8 cm x 4.5 cm
462 g
Radio access point
19.8 cm
13.8 cm
4.5 cm
462 g
Europe
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DQPSK, CCK, 64 QAM, QPSK, 16 QAM
Remote Management Protocol
SNMP 3, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
DHCP support, power over Ethernet (PoE), VLAN support, manageable, MAC address filtering, Wireless Distribution System (WDS) support, WLAN controller mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), 2T2R MIMO technology, rogue access point detection
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
External detachable
Antenna Qty
4
1 x 1000Base-T - RJ-45
EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, EN 60950-1, FCC Part 15 E, EN 301.893, EN 60601-1-2, DGT
PoE
External power adapter
14 Watt
50 °C
20 - 95% (non-condensing)
Scroll to top
