BT.com
Wishlist
Zyxel Dual-Band Hybrid Wireless N Access Point
Delivery
Standard Due date unavailable
To catch up the wave of 802.11n, the enterprise-level NWA3000-N series Access Point (AP) meets the requirement of the "n generation". The range provides various AP portfolios from single radio to concurrent radio, as well as dual-frequency APs. Designed to meet the requirements of SMB market segment, the NWA3000-N series is ideally suited for service delivery on mission-critical networks.
Zyxel NWA-3160-N - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 120 Mbps
Manageable access points: 24
Power Over Ethernet (PoE) Supported
PoE
19.8 cm x 13.8 cm x 4.5 cm
439 g
2 years warranty
Radio access point
19.8 cm
13.8 cm
4.5 cm
439 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DQPSK, CCK, 64 QAM, QPSK, 16 QAM
Remote Management Protocol
SNMP 3, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
DHCP support, power over Ethernet (PoE), VLAN support, manageable, MAC address filtering, Wireless Distribution System (WDS) support, WLAN controller mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), rogue access point detection
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 1000Base-T - RJ-45
EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, EN 60950-1, FCC Part 15 E, EN 301.893, EN 60601-1-2, DGT
PoE
External power adapter
10 - 90% (non-condensing)
Scroll to top
