BT.com
Wishlist
Zyxel Armor Z1 Dual Band AC2350 Wireless Router
Delivery
Standard Due date unavailable
Deploy a powerful wireless network that can deliver fast wireless data speeds for lag free online multiplayer gaming experience and smoothly stream high-definition videos with the ZyXEL Armor Z1, AC2350 Dual-Band Wireless Gigabit Router.
Zyxel Armor Z1 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
IGMPv2, IGMP, static IP routing
Firewall protection, NAT support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), dynamic DNS server, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, DLNA Media Server, DHCP client, Denial of Service (DoS), StreamBoost, PPTP passthrough, L2TP passthrough
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
29.77 cm x 20.78 cm x 7.15 cm
840 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
PPPoE, DHCP
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac, FCC, LVD
1 x 1.4 GHz
RAM
512 MB
Flash Memory
4 GB
Status Indicators
Power, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
29 Watt
1 x network cable
Europe
29.77 cm
20.78 cm
7.15 cm
840 g
10 - 90% (non-condensing)
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
