BT.com
Wishlist
Zyxel ANT3316 5Ghz 16dBi 2 Element MIMO Directional Outdoor Antenna
Zyxel ANT3316 5Ghz 16dBi 2 Element...
£305.91
£305.91
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
ZyXEL ANT3316 - antenna
Antenna
Indoor / Outdoor
Outdoor
21 cm x 21 cm x 7.3 cm
800 g
Product Material
ABS plastic
Directivity
Directional
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi, 16 dBi
2 years warranty
Antenna
Indoor / Outdoor
Outdoor
Product Material
ABS plastic
21 cm
21 cm
7.3 cm
800 g
Enclosure Colour
Grey white
Aerial
Directivity
Directional
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi, 16 dBi
Voltage Standing Wave Ratio (VSWR)
2.0:1
Horizontal Beamwidth
19°
Vertical Beamwidth
21°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
2 x N connector male
UV protection, MIMO technology
-40 °C
80 °C
Scroll to top
