BT.com
Wishlist
Zyxel ANT3315 5Ghz 15dBi 2 Element MIMO Directional Antenna
Zyxel ANT3315 5Ghz 15dBi 2 Element...
£318.31
£318.31
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
ZyXEL ANT3315 - antenna
Antenna
56 cm x 12 cm x 14.5 cm
1.4 kg
Product Material
ABS plastic
Application
Outdoor
Directivity
Directional
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi
2 years warranty
Antenna
Product Material
ABS plastic
56 cm
12 cm
14.5 cm
1.4 kg
Enclosure Colour
Grey
Aerial
Application
Outdoor
Directivity
Directional
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi
Voltage Standing Wave Ratio (VSWR)
2.0:1
Horizontal Beamwidth
60°
Vertical Beamwidth
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
2 x N connector male
UV protection, MIMO technology
2 years warranty
Service & Support Details
-40 °C
80 °C
Scroll to top
