BT.com
Wishlist
Zyxel ANT1310 2.4Ghz 10dBi 2 Element MIMO Ceiling Mount Indoor Antenna
Zyxel ANT1310 2.4Ghz 10dBi 2...
£97.15
£97.15
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
ZyXEL ANT1310 - antenna
Antenna
Placing / Mounting
Ceiling mountable
Indoor / Outdoor
Indoor
13.3 cm x 13.3 cm x 4.2 cm
130 g
Product Material
ABS plastic
Directivity
Directional
Frequency Range
2.3 - 2.7 GHz
Gain
9 to 10 dBi
2 years warranty
Antenna
Placing / Mounting
Ceiling mountable
Indoor / Outdoor
Indoor
Product Material
ABS plastic
13.3 cm
13.3 cm
4.2 cm
130 g
Enclosure Colour
White
Aerial
Directivity
Directional
Frequency Range
2.3 - 2.7 GHz
Gain
9 to 10 dBi
Voltage Standing Wave Ratio (VSWR)
1.5:1
Horizontal Beamwidth
51°, 66°
Vertical Beamwidth
51°, 66°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
2 x SMA male
Mounting Kit
Included
UV protection, MIMO technology
-10 °C
55 °C
Scroll to top
