BT.com
Wishlist
Zyxel AMG1302-T10B Wireless N ADSL2+ Router
Delivery
Standard Due date unavailable
High Speed 802.11n ADSL2+ Wireless Gateway - 802.11n technology for extreme performance and coverage
The ZyXEL AMG1302-T10B features 802.11n technology with data rates of up to 300 Mbps, it providing stable, reliable wireless connections for high-speed data and multimedia delivery. The AMG1302-T10B eliminates dead zones and, extends coverage and is backward compatible with any IEEE 802.11 b/g Wi-Fi certified device. Besides, the AMG1302-T10B supports multiple SSIDs with individual security and scheduling settings that facilitates different service levels for service providers.
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall security
The Stateful Packet Inspection (SPI) Firewall exams inspects header and footer of a packet, and it also to ensure the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, the ZyXEL AMG1302-T10B provides the first-line defense against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
The AMG1302-T10B comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
TR-069 remote management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "plug-and-play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
Easy customization with ROM-D function
Service Providers providers need to have a quick and, easy way to customize and manage different firmware versions before networking devices are distributed to fulfill specific requirements in from different customers. The ZyXEL AMG1302-T10B features ROM-D to provide the flexibility to for service providers to change default configurations settings through an easy way of uploading of a new customized configuration file.
Zyxel AMG1302-T10B - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, IPSec, PPPoE
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
NAT support, VPN support, packet filtering, ALG support, dynamic DNS server, IPv6 support, VPN passthrough, URL filtering, Access Point operational mode, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, port forwarding, reset button, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client, Denial of Service (DoS), PPPoE passthrough, PPTP passthrough
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
16.4 cm x 11.5 cm x 2.8 cm
201 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPTP, IPSec, PPPoE
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, FCC, EN 60950-1
Status Indicators
Power, WLAN, WAN, LAN, ADSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex L
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
Aerial
Internal
Antenna Qty
2
Gain Level
3 dBi
External power adapter
United Kingdom
16.4 cm
11.5 cm
2.8 cm
201 g
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£12.04
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.56
Scroll to top
