Click to visit BT.com
BT.com
Wishlist
ZyXEL AMG1302-T10A Wireless N ADSL2+ Router
Quicklinx: 8F4YWS00
Mfr#: AMG1302-T10A-GB01V1F
802.11n Technology for extreme performance and coverage
The ZyXEL AMG1302-T10A featuring 802.11n Technology provides the ultimate solution for speed and coverage. With data rate up to 300 Mbps, the AMG1302-T10A provides stable and reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by using IEEE 802.11n technology and is backward compatible with any IEEE 802.11b/g Wi-Fi certified device.
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. With WPS, the device will automatically configure a wireless network with a network name (SSID), strong WPA data encryption and authentication. WPS makes the configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall Security
The SPI Firewall works on the network layer by examining header and footer of a packet, and it also ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), DoS (Denial of Service) and DDoS features, the AMG1302-T10A provides the first-line defense against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
The AMG1302-T10A comes equipped with essential ATM QoS features. Service providers can freely design their QoS policy and prioritize the mission-critical services such as IPTV and VoIP based on their service plans. This increases network efficiency and productivity to enable service providers to bring real multi-play into the daily life of residential users.
TR-069 remote management
With TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end users. This unique feature not only offers true "plug-and-play" experience but also reduces the complexity of deployment, and therefore saves operating and maintenance costs for service providers.
Header / Manufacturer
ZyXEL Communications
Header / Model
AMG1302-T10A
Connection Type
ADSL (BT)
Wireless router
Speed
150 Mbps
Networking / Connectivity Technology
Wired, Wireless
Networking / Wireless Protocol
802.11b/g/n
Header / Packaged Quantity
1
Networking / WAN Ports Qty
1
Modem / Digital Signaling Protocol
ADSL2, ADSL2+, READSL
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, MD5, TLS, TTLS, WPA, WPA2
Networking / Integrated Switch
4-port switch
Networking / Remote Management Protocol
CLI, HTTP, HTTPS, SNMP 1, SNMP 2, Telnet, TR-069
Networking / Form Factor (FE)
Desktop
Standards
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Rackmount or External
External
Networking / Routing Protocol
IGMP, IGMPv2, RIP-1, RIP-2
Networking / Network / Transport Protocol
IPSec, PPPoE, PPTP
Modem / Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex L, ITU G.992.3 Annex M, ITU G.992.5, ITU G.992.5 Annex L, ITU G.992.5 Annex M
Header / Compatibility
PC
Header / Country Kits
United Kingdom
Dimensions & Weight / Height
3.1 cm
Dimensions & Weight / Width
17.5 cm
Dimensions & Weight / Depth
11.7 cm
Dimensions & Weight / Weight
200 g
