BT.com
Wishlist
Zyxel 802.11bgn Wireless Access Point
Zyxel 802.11bgn Wireless Access...
£129.78
£129.78
Add to wishlist
Delivery
Standard Due date unavailable
The ZyXEL NWA5120 series 802.11 a/b/g/n unified access point is a highly future-proof WLAN solution perfect for growing business, hospitality and education environments. With a 2-in-1 standalone/managed AP design, users can initially use it as a standalone AP, and convert it to a controller-managed AP when Wi-Fi demand grows. The series is designed with industry-leading technology to provide trouble-free wireless quality to lower IT overhead. The embedded antennas and signal output are fine-tuned to provide easy RF planning and maximum signal coverage. It also supports such features as dynamic channel selection, load balancing and pre-authentication for superb Wi-Fi experience.
ZyXEL NWA5121-N - radio access point
Radio access point
In-ceiling
Europe
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 12 V
13 cm x 13 cm x 5.45 cm
230 g
Radio access point
13 cm
13 cm
5.45 cm
230 g
Europe
In-ceiling
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK
Spread Spectrum Method
DSSS
Remote Management Protocol
CLI
Frequency Band
2.4 GHz
VLAN support, manageable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), CAPWAP support, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, plenum-rated, DHCP client, Energy Efficient Ethernet, Maximum Likelihood Demodulation (MLD)
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna Qty
2
Gain Level
3 dBi
1 x 100Base-TX (PoE) - RJ-45
MTBF
627,152 hours
BSMI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 301.489.1, EN 301.489.17, FCC Part 15.247, IEC 60950-1, EN 60950-1, FCC Part 15.107, BSMI CNS 13438, BSMI CNS 14336, IEC 60601-1-2:2007, EN 300 328 V1.7.1
PoE
Internal power supply
DC 12 V
4 Watt
50 °C
10 - 90% (non-condensing)
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
