BT.com
Wishlist
Zyxel 802.11agn Dual-Radio Outdoor Wireless Access Point
Delivery
Standard Due date unavailable
Centralized administration simplifies planning significantly. The NWA5000-N series is designed to enable easy deployment and instant provisioning. The NWA5000-N series supports the 802.3af or 802.3at Power over Ethernet (PoE) standard to utilize the Ethernet cable for minimized cabling construction.
To IT administrators, one of the major concerns is to deploy a WLAN infrastructure with flexible guess access while providing internal users a separated secure network at the same time. The NWA5000-N series features end-to-end guest network solutions to provide a guest account generator and web authentication functions. The ZyXELNWA5000-N series can eliminate concerns for IT administrators while providing the best Wi-Fi coverage at the same time. It is an ideal and secure choice for business Wi-Fi deployments.
Zyxel NWA-5550-N - radio access point
Radio access point
External - outdoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Throughput: 140 Mbps
Power Over Ethernet (PoE) Supported
PoE
25.7 cm x 25.7 cm x 5.1 cm
1.36 kg
Radio access point
Ruggedized Design
Outdoor
25.7 cm
25.7 cm
5.1 cm
1.36 kg
Europe
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Remote Management Protocol
SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, system, WLAN, LAN
Power over Ethernet (PoE), VLAN support, manageable, Wireless Distribution System (WDS) support, full duplex mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, DHCP client
Encryption Algorithm
WPA2, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Secure Shell (SSH)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az
1 x 1000Base-T - RJ-45 , 1 x management , 4 x aerial - N connector
EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, UL 2043, FCC, RoHS, EN 60950-1, FCC Part 15 E, EN 301.893, EN 60601-1-2, DGT
PoE
-40 °C
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£12.04
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.56
Scroll to top
