BT.com
Wishlist
Zyxel 8-port Gigabit Unmanaged PoE Switch
Zyxel 8-port Gigabit Unmanaged PoE...
£69.54
19 in stock
£69.54
Add to wishlist
Delivery
Standard 3-5 working days
The ZyXEL GS1100 series is the best solution for instant Gigabit connectivity in office environments demanding silent operation and better energy efficiency. With power-saving functions, Gigabit Ethernet and a fanless design, the GS1100 Series provides Plug-and-Play simplicity for high-bandwidth network applications. The GS1100-8HP is an 8-port Gigabit switch that complies with the IEEE 802.3at Power over Ethernet (PoE) plus standard, providing 4 PoE ports with up to 30 watts per port.
Zyxel GS1100-8HP - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 + 4 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
21 cm x 10.4 cm x 2.7 cm
540 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
Jumbo Frame Support
9000 bytes
Status Indicators
Port status, link activity, power, PoE
4 x 1000Base-T - RJ-45 - PoE , 4 x 1000Base-T - RJ-45
Power supply - external
90 Watt
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1
United Kingdom
21 cm
10.4 cm
2.7 cm
540 g
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
