BT.com
Wishlist
Zyxel 8-Port Desktop Gigabit Ethernet Switch
Delivery
Standard Due date unavailable
Optimized for Smooth VoIP and Data Exchange
The ZyXEL GS-108B v2 8-Port Desktop Gigabit Ethernet Switch connects network devices and the home network at blazing Gigabit speed. The newly designed QoS ports guarantee smooth transfer for bandwidth-intensive applications such as VoIP and data communications.
Compact, sturdy switch with alternative wall-mount design
The GS-108B v2 fits any environment. Regardless of desktop or wall-mount installation, its sturdy, compact design provides more flexibility for wired home networks.
Fast, reliable wired connectivity
Without any manual configuration, the GS-108B v2 can boost data transfer speed for connected network devices such as IP phones, network storages, PCs and laptops to the network at blazing-fast Gigabit speed.
Optimized for smooth VoIP and data exchange
The GS-108B v2 has 3 QoS ports with an assigned high- and medium-priority mechanism to enhance the stability of VoIP and data exchange. Just connect network devices such as IP phones, PCs, laptops or network storages to the high-priority or medium-priority ports of your choice, you can then enjoy smooth VoIP communication and data transfer at the same time.
ZyXEL GS-108B - v2 - switch - 8 ports - unmanaged - desktop
Switch - 8 ports - unmanaged
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching fabric bandwidth: 16 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), 128KB packet buffer, Energy Efficient Ethernet, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 120/230 V
16.4 cm x 9.8 cm x 2.6 cm
392 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP
Status Indicators
Power, link/activity
2 x 1000Base-T - RJ-45 - high priority , 2 x 1000Base-T - RJ-45 - medium priority , 4 x 1000Base-T - RJ-45
External power adapter
AC 120/230 V
5.5 Watt
FCC Class B certified, C-Tick, BSMI
United Kingdom
16.4 cm
9.8 cm
2.6 cm
392 g
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Accessories
£4.95
£3.78
£11.54
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.29
Scroll to top
