BT.com
Wishlist
Zyxel 4TB (2 x 2TB) NSA320 2-Bay Power 1.2GHz NAS
Delivery
Standard Due date unavailable
Powerful HD Multimedia Streaming at Fingertips!
With a powerful CPU and sufficient memory, the ZyXEL NSA320 2-Bay Power Media Server can quickly transfer, backup and stream large multimedia files at the same time. Its superior data read/write rate is up to four times faster than most generic network storage appliances. The NSA320 also handles multiple simultaneous 1080p high-definition streams to different UPnP and DLNA-certified devices such as Microsoft Xbox 360, Sony PS3 and DLNA TV in every room at home.
The NSA320 features rich server technologies for multimedia sharing. Acting as an iTunes server, SqueezeCenter, personal blog and photo album server, the NSA320 can simplify streaming and sharing multimedia on PCs, laptops and SqueezeBoxes.
ZyxelSuperior performance for simultaneous file transfers and multiple HD streams
With a powerful CPU and sufficient memory, the ZyXEL NSA320 2-Bay Power Media Server can quickly transfer, backup and stream large multimedia files at the same time. Its superior data read/write rate is up to four times faster than most generic network storage appliances. The NSA320 also handles multiple simultaneous 1080p high-definition streams to different UPnP and DLNA-certified devices such as Microsoft XBOX360, Sony PS3 and DLNA TV in every room at home.
ZyxelIntuitive user interface integrated with media player
With the user-friendly installation wizard, it's easy to manage and backup media files on the NSA320. You can also play music and slide shows directly from the NSA320 through the intuitive user interface integrated with a media player.
The NSA320 allows you to create a music playlist to play on the background of your slide shows. A newly designed alphabetical search bar provides you with a more convenient way to search within thousands of songs, photos and videos stored on the NSA320.
ZyxelzPilot™ for media auto-classification by easy drag-and-drop
The zPilot™ auto file classification function of the NSA320 enables you to easily store and manage media files through simple drag-and-drop operations. With the zPilot™ software installed via the NAS Starter Utility, you can drag one or more files/folders onto the desktop icon of zPilot™, and the files/folders will be identified and delivered automatically to the music, photo, video or other designated folders on the NSA320; users can easily check the data upload status during the process.
ZyXEL NSA-320 - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
Max Supported Capacity
4 TB
2 (installed) / 2 (max)
10.8 cm x 20.5 cm x 14.7 cm
1.06 kg
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 2 TB
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Microsoft Certification
Compatible with Windows 7
NAS server
Host Connectivity
Gigabit Ethernet
4 TB
4 TB
10.8 cm
20.5 cm
14.7 cm
1.06 kg
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 3.5"
2 x 2 TB
Network / Transport Protocol
TCP/IP, NTP, PPPoE, FTP, SMB, DDNS
Network Services Compatibility
DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), HTTP, HTTPS
Wake on LAN (WOL), Syslog support, IP address filtering, firmware upgradable, backup server, event log, iTunes server, Jumbo Frames support, Samba support, FTP server, temperature sensor, BitTorrent Client, UPnP Media Server, reset button, DLNA Media Server, Receive Side Scaling (RSS), eMule client, DHCP client, e-mail notification
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 0 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 3 x USB 2.0 - Type A
1 x network cable
FCC Class B certified, C-Tick, BSMI, RoHS
X external power adapter
32.2 Watt
Software Included
Drivers & Utilities
0 - 95% (non-condensing)
Scroll to top
