BT.com
Wishlist
Zyxel 48-port 10GbE Top-of-rack Switch with 40GbE Uplink
Zyxel 48-port 10GbE Top-of-rack...
£12,521.73
£12,521.73
Add to wishlist
Delivery
Standard Due date unavailable
Virtualization and data center consolidation have imposed higher bandwidth demands on data center networks. The competitive business landscape has also pushed forward the need for faster application deployments. Next-generation data centers need to provide the efficiency, flexibility and availability to facilitate business agility and competitiveness.
The ZyXEL XS3900-48F is a high-density top-of-rack (ToR) switch designed to facilitate fast and modularized application deployments in next-generation data centers. It supports DCBX, 802.1Qaz (ETS) and 802.1Qbb (PFC) protocols, and offers 10 GbE and 40 GbE connectivity to provide high bandwidth and ultra-low latency performance for converged networks and virtualized applications. With redundant and hot-swappable fan trays and power supply modules, the XS3900-48F offers the redundancy, reliability and availability for non-stop services.
Zyxel XS3900-48F - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit SFP+ + 4 x 40 Gigabit QSFP+
Performance
Switching capacity: 1.28 Tbps , Forwarding performance: 952.4 Mpps
Virtual interfaces (VLANs): 4000
MAC Address Table Size
128K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, traffic shaping, packet filtering, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Data Center Bridging Exchange (DCBX) support, priority-based flow control, enhanced transmission selection, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, front to back airflow, bandwidth control, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, DHCP client, Management Information Base (MIB), Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ), loop prevention, port isolation, redundant hot swappable fans, 9MB packet buffer, Class of Service (CoS), tagged VLAN, IGMP proxy, Two Rate Three Color Marking (TRTCM)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3aq, IEEE 802.3ba, IEEE 802.1Qbb, IEEE 802.1Qaz
Power Redundancy
44 cm x 45.5 cm x 4.3 cm
10.2 kg
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
128K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Port status, system, link/activity
48 x - SFP+ , 4 x - QSFP+ , 1 x USB - Type A - management , 1 x 1000Base-T - RJ-45 - management
Internal power supply
Installed Qty
2 (installed) / 2 (max)
Power Redundancy
Power Provided
350 Watt
232 Watt
MTBF
156,472 hour(s)
RoHS, EN 60950-1, EMC Class A
44 cm
45.5 cm
4.3 cm
10.2 kg
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-47 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
