Click to visit BT.com
BT.com
Wishlist
Zotac Z-Box Nano E2-1800 Radeon 7340 DDR3 Mini-PC
Quicklinx: 8B1MWS00
Mfr#: ZBOXNANO-AD12-BE
Raise your performance expectations for energy-efficient computing with the palm-sized ZOTAC ZBOX nano AD12 mini-PC powered by the AMD E2-1800 APU. Paired with AMD Radeon™ HD 7340 graphics, the ZOTAC ZBOX nano AD12 delivers the perfect synergy of GPU and CPU performance for a rich multimedia computing experience with flawless high-definition video playback capabilities and ultra-fast responsiveness for regular day-to-day computing tasks.
High performance energy-efficient computing is only a couple thumbscrews away with the ZOTAC ZBOX nano AD12 mini-PC thanks to a user-friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and a 204-pin DDR3-1333 SO-DIMM slot enables users to customize the internals of the ZOTAC ZBOX nano AD12 to their own needs while USB 3.0 and USB 2.0 ports, a 7-in-1 memory card reader (SD/SDHC/SDXC/MS/MS Pro/xD/MMC) and eSATA port provide greater external expansion capabilities for perfect palm-sized energy-efficient computing.
  • Assembly Configuration Barebone (no RAM, HDD, and OS)
  • CPU Integrated AMD E2-1800 APU 1.7 GHz Dual-Core
  • Chipset A68M
  • Cooler Type Fan
  • Onboard Video AMD Radeon™ HD 7340
  • Onboard Audio Combo analog / mini-Optical S/PDIF jack, Microphone jack
  • Onboard LAN 10/100/1000Mbps, Wifi 802.11n/g/b (300Mbps)
  • Memory Size Up to 8GB
  • Memory Slots 1 x 204-pin SO-DIMM
  • Memory Type DDR3-1333 SO-DIMM
  • SATA 1 eSATA, SATA 6.0 Gb/s compatible
  • Video Ports HDMI, DisplayPort
  • Dual-Link DVI Supported Yes
  • HDMI 1
  • DisplayPort 1
  • USB Ports 2 x USB 3.0 (back panel), 4 x USB 2.0 (2 on front panel, 2 on back panel)
  • Power Connector DC19V
  • Extra Features Bluetooth 3.0
Package Contents
  • 1 x ZOTAC ZBOX nano AD12
  • 1 x Power brick & cable
  • 1 x VESA monitor mount (w/4 screws)
  • 1 x MCE compatible remote w/ 2 CR2032 batteries
  • 1 x USB IR receiver
  • 1 x WiFi antenna
  • 1 x mini-Optical to Optical adapter
  • Dimensions 5in x 5in x 1.77in - 127mm x 127mm x 45mm
  • Weight 3.6300
  • Warranty 1-Year Standard
ZOTAC ZBOX nano AD12 - E2-1800 1.7 GHz - 0 MB - 0 GB
Personal computer - mini PC
1 x AMD E2-1800 1.7 GHz ( Dual-Core )
RAM
0 MB DDR3 SDRAM
Storage Controller
SATA ( SATA 6Gb/s / eSATA 6Gb/s )
Hard Drive
No HDD
Card Reader
7 in 1
Graphics Controller
AMD Radeon HD 7340
Audio Output
Integrated
GigE, 802.11b, 802.11g, 802.11n, Bluetooth 3.0
12.7 cm x 12.7 cm x 4.5 cm
Personal computer
Recommended Use
Home use
Product Form Factor
Mini PC
Processor / Chipset
CPU
AMD E2-1800 1.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
AMD A68M
RAM
Installed Size
0 MB
DDR3 SDRAM
SO-DIMM 204-pin
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
Card Reader
7 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 7340
Video Interfaces
HDMI, DisplayPort
HDCP compatible
Max Monitors Supported
2
Audio Output
Integrated
Integrated
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x memory
1 x eSATA , 1 x HDMI , 1 x DisplayPort , 4 x USB 2.0 ( 2 front, 2 rear ) , 2 x USB 3.0 , 1 x SPDIF output/headphones - mini-jack , 1 x microphone - mini-jack , 1 x LAN (Gigabit Ethernet)
Remote control, wireless antenna, VESA mounting kit, USB IR receiver
Power adapter
12.7 cm
12.7 cm
4.5 cm
