Click to visit BT.com
BT.com
Wishlist
Zotac Z-Box Nano AD10 Plus AMD Fusion E350 2GB DDR3 320GB WiFi Media PC
Quicklinx: 80DPWS00
Mfr#: ZBOXNANO-AD10-PLUS-B
A rich multimedia computing experience, ultra fast responsiveness and energy efficient performance all inside a discreet and contemporary mini-PC. Perfect for any home, the Z Box Nano AD10 Plus has a user friendly design and offers flawless HD video playback and high performance to take on any computing task with ease.
High performance energy-efficient computing is only a couple thumbscrews away with the ZOTAC ZBOX nano AD10 Plus mini-PC thanks to a user-friendly design that makes mastering the mini-PC quick and easy. Space for a 2.5-inch hard drive and a 204-pin DDR3-1066 SO-DIMM slot enables users to customize the internals of the ZOTAC ZBOX nano AD10 Plus to their own needs - a 320GB hard drive and 2GB of DDR3-1066 are included - while USB 3.0 and USB 2.0 ports, a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) and eSATA port provide greater external expansion capabilities for perfect palm-sized energy-efficient computing.
  • Universal Video Decoder (UVD)
  • Blu-ray hardware decode acceleration
  • Adobe Flash Player 10.1 acceleration
  • Microsoft DirectX 11 compatible
  • Microsoft DirectCompute ready
  • OpenGL 3.2 compatible
  • OpenCL compatible
  • Integrated 802.11n WiFi & Bluetooth 3.0
  • 2 Year Manufacturers Warranty
  • AMD Radeon HD 6310 GPU, AMD Dual-Core Processor E-350 (1.6 GHz), AMD M1 Chipset
  • Hard Drive & Memory: 320GB 5400RPM hard drive, 2GB DDR3 SO-DIMM
  • Display Outputs: HDMI (1080p w/8-channel audio), DisplayPort, HDCP compliant, Dual simultaneous displays
  • Front Ports: Power button, Hard drive LED, WiFi LED, IR receiver, 6-in-1 Memory card reader (MMC/SD/SDHC/MS/MS Pro/xD), Headphone/Audio out jack, Microphone jack
  • Rear Ports: Power connector, 2 USB 3.0 ports, 10/100/1000 Ethernet (RJ45), 2 USB 2.0 ports, eSATA connector, WiFi antenna connector
  • Inside the box: Zotac ZBOX nano AD10, Power brick & cable, VESA monitor mount (w/4 screws), MCE compatible remote w/ 2 CR2032 batteries, USB IR receiver, WiFi antenna
  • Warranty: 2 Years Manufacturers Warranty
ZOTAC ZBOX nano AD10 Plus - E-350 1.6 GHz - 2 GB - 320 GB
Personal computer - ultra small form factor
1 x AMD E-350 1.6 GHz ( Dual-Core )
RAM
2 GB DDR3 SDRAM - 1066 MHz - PC3-8500
Storage Controller
SATA ( SATA 6Gb/s )
Hard Drive
1 x 320 GB - SATA 6Gb/s
Card Reader
6 in 1
Graphics Controller
AMD Radeon HD 6310
Audio Output
Integrated
GigE, 802.11b, 802.11g, 802.11n, Bluetooth 3.0
OS Provided
No operating system
12.7 cm x 12.7 cm x 4.5 cm
2 years warranty
Personal computer
Recommended Use
Home use
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
AMD E-350 1.6 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB
DDR3 SDRAM
Memory Speed
1066 MHz
Memory Specification Compliance
PC3-8500
SO-DIMM 204-pin
Hard Drive
HDD
1 x 320 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
SATA - integrated
Controller Interface Type
SATA 6Gb/s
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 6310
Video Interfaces
HDMI, DisplayPort
HDCP compatible
Max Monitors Supported
2
Audio Output
Integrated
Integrated
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin
1 x headphones , 1 x microphone , 1 x HDMI , 1 x DisplayPort , 1 x eSATA , 2 x USB 2.0 , 2 x USB 3.0
Remote control, wireless antenna, VESA mounting kit, USB IR receiver
Power adapter
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
2 years warranty
Service & Support Details
12.7 cm
12.7 cm
4.5 cm
