Click to visit BT.com
BT.com
Wishlist
Zotac GeForce GTX 780 863MHz 3GB PCI-E 3.0 HDMI (Includes Splinter Cell 3-Game-Pack)
Quicklinx: 8Q2KWS00
Mfr#: ZT-70201-10P
Experience PC gaming like never before with surreal visuals and world-class performance with the ZOTAC GeForce GTX 780. The ZOTAC GeForce GTX 780 ushers in the next generation of PC gaming with unmatched visual realism and performance for the most demanding gamers and enthusiasts.
NVIDIA 3D Vision Surround technology enables the ZOTAC GeForce GTX 780 to drive up to three displays for high-quality triple display gaming with immersive stereoscopic 3D effects. NVIDIA 3-Way SLI readiness lets the most demanding enthusiast gamers combine up to three ZOTAC GeForce GTX 780 graphics cards for up to a 280-percent performance boost.
Includes Splinter Cell Compilation 3-Game pack coupon consisting of Splinter Cell BlackList, Splinter Cell Conviction, Splinter Cell Double Agent. Will be launched on 20th Aug, 2013
Get the best gaming, with NVIDIA GeForce Experience™ one-click drivers and settings."
  • NVIDIA GPU Boost 2.0 technology
  • NVIDIA Adaptive Vertical Sync Technology
  • NVIDIA SMX shader architecture
  • NVIDIA PhysX technology
  • NVIDIA CUDA technology
  • NVIDIA 3D Vision Surround support
  • NVIDIA SLI ready (3-way-SLI)
  • NVIDIA SHIELD gaming-portable ready
  • NVIDIA GeForce GTX 780 GPU
  • 2,304 processor cores
  • 3GB GDDR5
  • 384-bit memory bus
  • Engine clock (base): 863 MHz (boost): 900 MHz
  • Memory clock: 6008 MHz
  • PCI Express 3.0 (compatible with 1.1)*
Connectors
  • DisplayPort 1.2 (4K ready)
  • 2 x DL-DVI
  • VGA (with included adapter)
  • 1 x HDMI
  • Quad simultaneous display capable
  • HDCP compliant
  • SLI bridge connectors (3-way SLI)
Power Requirements
  • 700-watt power supply recommended
  • 250-watt max power consumption
HDTV Ready
  • ED 480p
  • HD 720p
  • HD 1080i
  • Full HD 1080p
  • Quad Full HD (4K)
Software Compatibility
  • NVIDIA GeForce driver
  • Microsoft DirectX 11.1 (feature level 11_0)
  • OpenGL 4.3
  • Microsoft Windows Vista/7/8 x86/x64
Dimensions
  • Height: 111.15mm (4.376in)
  • Width: 266.7mm (10.5in)
  • Box
  • Height: 335mm (13.19in)
  • Width: 257mm (10.12in)
  • Depth: 65mm (2.56in)
Inside The Box
  • ZOTAC GeForce GTX 780
  • Splinter Cell Compilation game bundle
  • DVI-to-VGA adapter
  • 1 x Dual 6-pin-to-8-pin PCIe adapters
  • 1 x Dual MOLEX-to-6-pin PCIe adapters
  • User manual
  • Driver disc
ZOTAC GeForce GTX 780 graphics card - GF GTX 780 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
3 GB GDDR5
Core Clock
863 MHz
Boost Clock
900 MHz
Stream Processors
2304
Effective Memory Clock
6.008 GHz
RAMDAC
400 MHz
Memory Interface
384-bit
Max Resolution
2560 x 1600
DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.3
26.67 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
2 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
863 MHz
Boost Clock
900 MHz
Stream Processors
2304
RAMDAC
400 MHz
Max Resolution
2560 x 1600
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready , HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
384-bit
Microsoft Windows Vista / 7 / 8, Microsoft Windows Vista / 7 / 8 (64-bit versions)
Required Power Supply
700 W
Additional Requirements
6-pin + 8-pin power connectors
250 Watt
Dual 6-pin PCIe to 8-pin power adapter, Dual 4 pin to 6 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, Splinter Cell Complilation 3-game pack coupon
26.67 cm
11.115 cm
2 years warranty
Service & Support Details
