Click to visit BT.com
BT.com
Wishlist
Zotac GeForce GTX 770 1059MHz 2GB PCI-E 3.0 HDMI
Quicklinx: 8QVLWS00
Mfr#: ZT-70301-10P
  • ZOTAC GeForce GTX 770 2GB
  • ZOTAC SKU ZT-70301-10P
  • Memory 2GB DDR5 256 bit
  • Engine Clock
  • Base Clock 1059 MHz (NV ref. 1046 MHz)
  • Boost Clock 1111 MHz (NV ref. 1085 MHz)
  • Memory Clock: 7010 MHz (7.0Gbps)
  • NVIDIA GPU Boost Technology
  • NVIDIA Adaptive Vertical Sync Technology
  • NVIDIA 3D Vision Surround Support
  • Microsoft DirectX 11 support
  • PCI Express 3.0 support
  • Two dual-link DVI (DVI-I + DVI-D) + HDMI + DP
  • Bundling/Software Features Two dual-link DVI (DVI-I + DVI-D) + HDMI + DP, Special bundle: Splinter Cell Compilation 3-game pack coupon, Boost Premium
ZOTAC GeForce GTX 770 graphics card - GF GTX 770 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 770
2 GB GDDR5
Core Clock
1059 MHz
Boost Clock
1111 MHz
Stream Processors
1536
Effective Memory Clock
7.01 GHz
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11.1, OpenGL 4.3
26.67 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
2 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1059 MHz
Boost Clock
1111 MHz
Stream Processors
1536
RAMDAC
400 MHz
Max Resolution
2560 x 1600
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0 , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Microsoft Windows Vista / 7 / 8, Microsoft Windows Vista / 7 / 8 (64-bit versions)
Required Power Supply
600 W
Additional Requirements
6-pin + 8-pin power connectors
Dual 6-pin PCIe to 8-pin power adapter, Dual 4 pin to 6 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, Splinter Cell Complilation 3-game pack coupon
26.67 cm
11.115 cm
1.39 kg
2 years warranty
Service & Support Details
