Click to visit BT.com
BT.com
Wishlist
Zotac GeForce GTX 760 993MHz 2GB PCI-Express 3.0 HDMI
Quicklinx: 8SMRWS00
Mfr#: ZT-70401-10P
Embrace fast, smooth and quiet gaming in the latest games with the innovative and feature-rich ZOTAC GeForce GTX 760. The ZOTAC GeForce GTX 760 takes gaming to the next level with serious power that enables gamers to crank up the settings and resolution for stunning visuals, super-fast frame rate and smooth performance.
NVIDIA GPU Boost 2.0 technology empowers the ZOTAC GeForce GTX 760 with dynamic overclocking intelligence to maximize clock speeds for that extra performance push in demanding situations. NVIDIA Surround technology enables the ZOTAC GeForce GTX 760 to drive up to three displays for high-quality triple display gaming for unmatched immersion.
FEATURES
  • NVIDIA GPU Boost technology
  • NVIDIA Adaptive Vertical Sync Technology
  • NVIDIA SMX shader architecture
  • NVIDIA PhysX technology
  • NVIDIA CUDA technology
  • NVIDIA 3D Vision Surround support
  • NVIDIA SLI ready (3-way)
SPECIFICATIONS
  • NVIDIA GeForce GTX 760 GPU
  • 1152 processor cores
  • 2GB GDDR5
  • 256-bit memory bus
  • Engine clock (base): 993 MHz (boost): 1059 MHz
  • Memory clock: 6008 MHz
  • PCI Express 3.0 (compatible with 1.1)*
CONNECTORS
  • DisplayPort 1.2 (4K ready)
  • HDMI 1.4a (4K ready, w/ audio)
  • DVI-I (VGA with included adapter)
  • DVI-D (digital only)
  • Quad simultaneous display capable
  • HDCP compliant
  • Dual SLI bridge connectors (3-way)
POWER REQUIREMENTS
  • 600-watt power supply recommended
  • 170-watt max power consumption
HDTV READY
  • ED 480p
  • HD 720p
  • HD 1080i
  • Full HD 1080p
  • Quad Full HD (4K)
SOFTWARE COMPATIBILITY
  • NVIDIA GeForce driver
  • Microsoft DirectX 11.1 (feature level 11_0)
  • OpenGL 4.3
  • Microsoft Windows 7/8 x86/x64
DIMENSIONS
  • Height: 111.15mm (4.376in)
  • Width: 240.03mm (9.45in)
INSIDE THE BOX
  • ZOTAC GeForce GTX 760 graphics card
  • DVI-to-VGA adapter
  • 2 x Dual MOLEX-to-PCIe 6-pin adapter
  • User manual
ZOTAC GeForce GTX 760 graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Monitors Supported
4
DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11.1, OpenGL 4.3
24.003 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
5 years warranty with product registration
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
1152
RAMDAC
400 MHz
Max Resolution
2560 x 1600
4
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, fan-cooled heatsink, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, HD/4k Ready, Nvidia SMX Engine , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
600 W
Additional Requirements
2 x 6 pin PCI Express power connector
170 Watt
2 x 4 pin to 6 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities
RoHS
24.003 cm
11.115 cm
Limited warranty - 5 years
Resources
The following resources are available for the Zotac GeForce GTX 760 993MHz 2GB PCI-Express 3.0 HDMI
