Click to visit BT.com
BT.com
Wishlist
Zotac GeForce GTX 760 1111MHz 2GB PCI-Express 3.0 HDMI AMP! Edition
Quicklinx: 8SMSWS00
Mfr#: ZT-70402-10P
Embrace fast, smooth and quiet on a supercharged level with the finely-tuned ZOTAC GeForce GTX 760 AMP! Edition. The ZOTAC GeForce GTX 760 AMP! Edition boosts the engine and memory clocks far beyond the stock levels for an extra performance kick in the most demanding gaming situations.
NVIDIA GPU Boost 2.0 technology empowers the ZOTAC GeForce GTX 760 AMP! Edition with dynamic overclocking intelligence to maximize clock speeds for that extra performance push in demanding situations. NVIDIA Surround technology enables the ZOTAC GeForce GTX 760 AMP! Edition to drive up to three displays for high-quality triple display gaming for unmatched immersion.
FEATURES
  • NVIDIA GPU Boost technology
  • NVIDIA Adaptive Vertical Sync Technology
  • NVIDIA SMX shader architecture
  • NVIDIA PhysX technology
  • NVIDIA CUDA technology
  • NVIDIA 3D Vision Surround support
  • NVIDIA SLI ready (3-way)
SPECIFICATIONS
  • NVIDIA GeForce GTX 760 GPU
  • 1152 processor cores
  • 2GB GDDR5
  • 256-bit memory bus
  • Engine clock (base): 1111 MHz (boost): 1176 MHz
  • Memory clock: 6208 MHz
  • PCI Express 3.0 (compatible with 1.1)*
CONNECTORS
  • DisplayPort 1.2 (4K ready)
  • HDMI 1.4a (4K ready, w/ audio)
  • DVI-I (VGA with included adapter)
  • DVI-D (digital only)
  • Quad simultaneous display capable
  • HDCP compliant
  • Dual SLI bridge connectors (3-way)
POWER REQUIREMENTS
  • 600-watt power supply recommended
  • 185-watt max power consumption
HDTV READY
  • ED 480p
  • HD 720p
  • HD 1080i
  • Full HD 1080p
  • Quad Full HD (4K)
SOFTWARE COMPATIBILITY
  • NVIDIA GeForce driver
  • Microsoft DirectX 11.1 (feature level 11_0)
  • OpenGL 4.3
  • Microsoft Windows 7/8 x86/x64
DIMENSIONS
  • Height: 111.15mm (4.376in)
  • Width: 195.07mm (7.68in)
INSIDE THE BOX
  • ZOTAC GeForce GTX 760 AMP! Edition
  • DVI-to-VGA adapter
  • 2 x Dual MOLEX-to-PCIe 6-pin adapter
  • User manual
  • Driver disc
ZOTAC GeForce GTX 760 - AMP! Edition - graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1111 MHz
Boost Clock
1176 MHz
CUDA Cores
1152
Effective Memory Clock
6.208 GHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
DVI-D (dual link) , DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11.1, OpenGL 4.3
19.507 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
2 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1111 MHz
Boost Clock
1176 MHz
CUDA Cores
1152
RAMDAC
400 MHz
Max Resolution
2560 x 1600
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia SMX Engine , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.208 GHz
Microsoft Windows 7 / Windows 8 (32 bits), Microsoft Windows 7 / Windows 8 (64 bits)
Required Power Supply
600 W
2 x 4 pin to 6 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities
RoHS
19.507 cm
11.115 cm
Resources
The following resources are available for the Zotac GeForce GTX 760 1111MHz 2GB PCI-Express 3.0 HDMI AMP! Edition
