Click to visit BT.com
BT.com
Wishlist
Zotac GeForce GTX 660 Ti 928MHz 2GB PCI-Express 3.0 HDMI
Quicklinx: 88D4WS00
Mfr#: ZT-60802-10P
Experience a new dimension of gaming with the ZOTAC GeForce® GTX 660 Ti powered by the Latest NVIDIA® GeForce® architecture that combines performance, power efficiency and affordability. The ZOTAC GeForce® GTX 660 Ti raises the performance bar and is a must-have upgrade for garners seeking the best experience in today's visually demanding games.
New NVIDIA Adaptive Vertical Sync technology adapts the monitor's vertical-sync dynamically to current frame rates for maximum gaming smoothness and playability with the ZOTAC GeForce® GTX 660 Ti. Take your gaming experience to the next Level with NVIDIA® Surround™ technology for an unmatched immersive gaming experience with a single ZOTAC GeForce GTX 660 Ti graphics card and multiple displays.
  • NVIDIA GPU Boost technology
  • NVIDIA Adaptive Vertical Sync Technology
  • NVIDIA SMX shader architecture
  • NVIDIA PhysX® technology
  • NVIDIA CUDA® technology
  • NVIDIA 3D Vision™ Surround support
  • NVIDIA SLI ready (3-way)
ZOTAC GeForce GTX 660 Ti graphics card - GF GTX 660 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 660 Ti
2 GB GDDR5
Core Clock
928 MHz
Boost Clock
1006 MHz
Effective Memory Clock
6.008 GHz
RAMDAC
400 MHz
Memory Interface
192-bit
Max Resolution
2560 x 1600
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
19.1262 cm x 11.115 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
928 MHz
Boost Clock
1006 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
4
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Dual Fan Design, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Microsoft Windows Vista / XP, Microsoft Windows 7 (32/64 bits)
Required Power Supply
600 W
150 Watt
2 x 6 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities
RoHS
19.1262 cm
11.115 cm
Resources
The following resources are available for the Zotac GeForce GTX 660 Ti 928MHz 2GB PCI-Express 3.0 HDMI
