BT.com
Wishlist
Zotac GeForce GTX 660 993MHz 2GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
Zotac GTX 660 2GB GDDR5 Dual DVI HDMI DisplayPort
Supercharge your gaming experience with the ZOTAC GeForce GTX 660 powered by the latest NVIDIA GeForce Architecture that combines performance, power efficiency and affordability. The ZOTAC GeForce GTX 660 raises the performance bar and is a must-have upgrade for gamers seeking the best experience in totday's visually demanding games.
NVIDIA Adaptive Vertical Sync technology adapts the monitor's vertical-sync dynamically to current frame rates for maximum gaming smoothness and playability with the ZOTAC GeForce GTX 660. Take your gaming experience to the next level with NVIDIA Surround technology for an unmatched immersive gaming experience with a single ZOTAC GeForce GTX 660 Graphics card and triple displays.
  • NVIDIA GeForce GTX 660 GPU
  • 960 processor cores
  • 2GB GDDR5 Memory
  • 192-bit memory bus
  • Engine Clock - (base) 993MHz (boost) 1059MHz
  • Memory Clock - 6608MHz
  • PCI-Express 3.0
  • Connectors: Dual DVI - DVI-I x 1 DVI-D x 1 + HDMI 1.4a + DisplayPort 1.2
  • Power Requirements: 600 Watt PSU recommended / 140 Watt max power consumption
  • NVIDIA GPU Boost technology
  • NVIDIA Adaptive Vertical Sync technology
  • NVIDIA 3D Vision Surround support
  • Microsoft DirectX 11 support
  • PCI Express 3.0 support
  • Two dual-link DVI (DVI-I + DVI-D) + HDMI + DP
ZOTAC GeForce GTX 660 graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.5 cm x 19.1 cm x 11.1 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
4
API Supported
Dual Slot Fan Cooler, Nvidia 3D Vision Surround Ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Additional Requirements
6 pin PCI Express power connector
140 Watt
6 pin to 4 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, ZOTAC Boost Premium, TrackMania 2 Canyon (3 days trial) Game Pass
3.5 cm
19.1 cm
11.1 cm
Scroll to top
