BT.com
Wishlist
Zotac GeForce GTX 470 1280MB PCI-Express HDMI (Fermi)
Delivery
Standard Due date unavailable
Propel your computing power to uncharted heights with the class-leading ZOTAC GeForce® GTX 470 graphics card designed for phenomenal performance in gaming and GPU computing applications. The ZOTAC GeForce® GTX 470 features compatibility with the latest Microsoft® DirectX® 11 and OpenGL® 3.2 games and applications while enhancing the experience with realistic physics processing through NVIDIA® PhysX® technology and superior gaming immersion with NVIDIA® 3D Vision™ Surround technology.
NVIDIA® CUDA™ technology with DirectCompute and OpenCL support harnesses the power of the graphics processor in the ZOTAC GeForce® GTX 470 and takes it beyond the heights of gaming by accelerating the most demanding tasks such as image and video editing for incredible performance improvements unmatched by traditional system CPUs. Dual dual-link DVI and mini-HDMI outputs with HDCP compliance ensures the ZOTAC GeForce® GTX 470 to connect up to three digital monitors or high-definition televisions for crystal clear clarity.
ZOTAC GeForce GTX 470 graphics card - GF GTX 470 - 1.25 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GTX 470
1.25 GB GDDR5
Core Clock
607 MHz
Effective Memory Clock
3.348 GHz
RAMDAC
400 MHz
Memory Interface
320-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
2 x DVI-I (dual link) , HDMI , VGA - with adapter , HDMI - with adapter
API Supported
DirectX 11, OpenCL, OpenGL 3.2, DirectCompute
6.78 cm x 33.7 cm x 26 cm
Microsoft Certification
Compatible with Windows 7
2 years warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
607 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
2
API Supported
Nvidia SLI Multi-GPU Technology, Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
Size
1.25 GB
GDDR5 SDRAM
Effective Clock Speed
3.348 GHz
Bus Width
320-bit
Microsoft Windows Vista / XP / 7
Additional Requirements
Two additional power connectors
6 pin power cable, Dual 6-pin PCIe to 8-pin power adapter
1 x DVI-VGA adapter , 1 x mini HDMI-HDMI adapter
Software Included
Drivers & Utilities
Supported Windows 7 Features
Windows Media Center
RoHS
6.78 cm
33.7 cm
26 cm
0.9 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Zotac GTX470
Reviewed by on 12/08/2010
Forget all the whining about heat and noise currently going on in the press/web reviews. This card is quieter than my previous 8800 GTS512, which was a big surprise to me as I could only just perceive the noise of the 8800 above the case fans!
I'm very pleased indeed.
Scroll to top
