BT.com
Wishlist
Zoostorm Pentium Dual Core B980 2.4ghz 4GB 320GB DVDRW No OS
Delivery
Standard Due date unavailable
The Zoostorm 15.6' Notebook is designed around the principles of productivity, longevity and low total costs of ownership. Using the best quality, energy saving components, the Zoostorm 15.6' Notebook is also designed and configured to work with popular business applications. In short this is a great reliable notebook for everyday home and business use.
Specification
  • Processor: Intel© Dual Core B980 (2M Cache, 2.40 GHz)
  • Operating System: NO/ OS
  • Storage: 320GB SATA HDD
  • Wireless: WiFi 802.11 10/100/1000MB b/g/n
  • Memory: 4GB DDR3 1066MHz RAM
  • Graphics: Intel© HD Graphics 3000
  • Display: 15.6'' High Definition (1366x768 pixels) 16:9 Panel
  • Audio: High Definition, built in microphone, built in 2 speakers
  • Power Supply: 6 cell Smart Lithium Ion battery, full AC Power Adapter
  • Card Reader: 9-in-1, MMC/ RSMMC, SD/ Mini SD, SDHC/SDXC
  • Dimensions: 374 (w) x 250 (d) x 14.3~34.1(h) mm
  • Battery life: 300 minutes approx.
  • Security: Kensington© Lock
  • Camera: 1.3 Mega-pixel front
  • Weight: 2.35kg
  • Warranty: 1 Year Return To Base parts and labour
  • 1 x HDMI output port
  • 3 x USB 2.0 port
  • 2 x Mini-PCIe port
  • 1 x VGA port
  • 1 x RJ45 port
  • 1 x DC Jack
  • 1 x Headphone Jack
  • 1 x Microphone Jack
Notebook
Processor / Chipset
CPU
Intel Pentium B980
Number of Cores
Dual-Core
Front Side Bus
400 MHz
RAM
4 GB
Slots Qty
2
Storage
Main Storage
320 GB HDD
Display
15.6"
Resolution
1366 x 768 (HD)
Widescreen
Audio & Video
Sound
Microphone
Input
Touchpad
AC Adapter
Input
(50/60 Hz)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Zoostorm B980
Reviewed by David on 17/04/2013
I bought this laptop because it had no operating system and I was planning to put Ubuntu Linux on it.
Everything worked fine with Ubuntu except the wireless which would not work with linux.
I eventually installed Ubuntu 13.04 which is not officialy released until 25 April 2013 and this works fine. So if like me you bought one of these for linux the answer is 13.04 and you will have a good machine.
Scroll to top
