BT.com
Wishlist
Zebra ZXP Series 3 Colour Card Printer
Zebra ZXP Series 3 Colour Card...
£941.05
12 in stock
£941.05
Add to wishlist
Delivery
Standard 1-3 working days
The ZXP series 3 is unique to the card printing market, employing several advanced features that provide high performance at an attractive price. The ZRaster host-based image processing technology takes advantage of the increased processing power of today's PCs to significantly optimize image and print quality while increasing overall print speed throughput. This permits greater sophistication in the image optimizations without sacrificing printer speed or adding extra cost. Zebra high performance ribbons employ an improved chemical formulation specifically designed for fast high-quality image printing, providing more efficient dye transfer and greater durability under high-speed printing conditions.
Zebra ZXP Series 3 - plastic card printer - colour - dye sublimation
Printer Type
Plastic card printer - dye sublimation - colour
5.3 kg
United Kingdom, Europe
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
85.6 mm x 54 mm
Print Speed
Up to 700 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour dual-sided - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
Automatic Duplexing
USB 2.0
RAM Installed (Max)
32 MB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, Interleaved 2 of 5, PDF417, Code 128B, Code 128C
Media Type
PVC card, PVC composite card
Total Media Capacity
100 cards
Printer Features
Zebra ZRaster technology
AC 120/230 V
Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
2 years warranty
20 cm x 36.8 cm x 23.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0
300 dpi
Automatic Duplexing
Barcodes
Printer Features
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Max Media Size
85.6 mm x 54 mm
Card / Label Sizes
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Max Media Capacity
100 cards
Output Trays Capacity
45 cards
1 x USB 2.0 - 4 pin USB Type B
1 x USB cable
FCC Class A certified
Power adapter
AC 120/230 V
Frequency Required
50/60 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
30 °C
20 - 65% (non-condensing)
20 cm
36.8 cm
23.6 cm
5.3 kg
Scroll to top
