BT.com
Wishlist
Zebra ZT220 Printer
Zebra ZT220 Printer
£536.40
Zebra ZT220 Printer
13 in stock
£536.40
Add to wishlist
Delivery
Standard 1-3 working days
Zebra incorporated extensive customer feedback, as well as the legacy of the industry leading Stripe and S4M printers, to create the ZT200 Series family of printers with elegant space saving design, effortless setup, intuitive user operation, and ease of service and maintenance.
ZT220 industrial printer offers a high impact polymer case and simple single-use three button interface for simpler applications.
Zebra ZT200 Series ZT220 - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
9.1 kg
United Kingdom, Europe
Max Media Size
Roll (11.4 cm)
Min Media Size (Custom)
19.4 mm
Max Media Size (Custom)
114 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W - Roll (11.4 cm)
Max Resolution (B&W)
203 dpi
Image Enhancement Technology
Multi-level Element Energy Equalizer
USB, serial
400 MHz
RAM Installed (Max)
128 MB SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
ZPL, ZPL II, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
Media Type
Labels, continuous paper labels, die cut labels
Tear bar
Printer Features
Zebra Programming Language (ZPL) support, XML-enabled printing, Multi-level Element Energy Equalizer (E3)
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
1 year warranty
24.2 cm x 43.2 cm x 27.7 cm
Printer Type
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi - Roll (11.4 cm)
Built-in Devices
Tear bar
Wired
USB, serial
203 dpi
Language Simulation
Tear bar
Fonts Included
1 x scalable , 7 x bitmapped
Barcodes
Printer Features
400 MHz
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
19.4 mm
114 mm x 991 mm
Media Sizes
Roll (1.94 - 11.4 cm)
Max Printing Width
104 mm
Max Printing Length
3988 mm
Media Thickness Range
0.076 mm - 0.25 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm, 25 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB
Reflective media sensor, transmissive media sensor
Power Factor Correction (PFC), LED indicator
VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B, CCC, KCC, GOST-R, S Mark, cTUVus, UkrSEPRO
Power supply - internal
AC 120/230 V
Frequency Required
47 - 63 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 85% (non-condensing)
24.2 cm
43.2 cm
27.7 cm
9.1 kg
Weight (Shipping)
11.4 kg
Scroll to top
