BT.com
Wishlist
Zebra QLn420 Printer - Bluetooth and WLAN Dual Radio
Zebra QLn420 Printer - Bluetooth...
£633.27
More than 50 in stock
£633.27
Add to wishlist
Delivery
Standard 1-3 working days
Zebra's popular QL family of direct thermal mobile label printers has built a highly satisfied following based upon its proven drop-resistant durability; user-friendly, productivity-boosting features; and easy integration. As Zebra's third generation of QL printers, the QLn printers extend these QL-platform benefits to the "nth" power.
The QLn420's over-molding and tempered-glass display - coupled with its seamless, one-piece design - make it more durable than ever before. The QLn printer can boost your operation's productivity through a larger, sharper, easier-to- navigate display; faster, higher-quality printing; a variety of proactive alerts that help keep working printers in employees' hands; and many convenient charging accessories. And, your IT department will find the QLn printer more intuitive to integrate into existing platforms thanks to Zebra's Link-OS environment.
With Zebra's Link-OS environment - an innovative operating system combining a powerful Multiplatform Software Development Kit (SDK) and software applications - the QLn family of printers is easy to integrate, manage and maintain from any location around the globe. Enabled with Print Touch, these Link-OS printers offer web page launching features using Near Field Communication (NFC), making it easy to access Zebra's extensive knowledge base of how-to videos and product support.
Zebra QLn 420 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
Portable
1.1 kg
Max Media Size
Roll (11.2 cm)
Min Media Size (Custom)
51 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 102 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, serial, Wi-Fi(n), NFC, Bluetooth 3.0
400 MHz
RAM Installed (Max)
128 MB
Flash Memory Installed (Max)
256 MB
Language Simulation
ZPL, EPL, Comtec Printer Control Language (CPCL)
Barcodes
Code 93, Code 39, UCC/EAN-128, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, FIM, TLC39
Media Type
Labels, linerless labels, receipt labels, die cut labels
Fonts
CG Triumvirate Bold Condensed
Styles & Effects
Rotated text
Fixed gap/bar media sensor, real time clock, label sensor, Black Mark sensor, tear bar
Display Resolution
240 x 128
Keyboard
7 keys
Required 1 Lithium Ion Included Qty 1
Microsoft Certification
Compatible with Windows 7
1 year warranty
16.5 cm x 8.25 cm x 18.7 cm
Printer Type
Printer
Print Speed
Up to 102 mm/sec - max speed - 203 dpi
Built-in Devices
Status LCD, tear bar
Wireless
203 dpi
Language Simulation
Fonts
Styles & Effects
Rotated text
Display Resolution
240 x 128
Keyboard
7 keys
Fonts Included
25 x bitmapped , 1 x scalable
Barcodes
400 MHz
RAM
RAM Installed (Max)
128 MB
Flash Memory
Flash Memory
256 MB
Media Handling
Media Type
Max Media Size
Roll (11.2 cm)
51 mm
112 mm
Media Sizes
Roll (5.1 - 11.2 cm)
Max Printing Width
104 mm
Max Printing Length
813 mm
Media Thickness Range
0.0813 mm - 0.1905 mm
Roll Maximum Outer Diameter
66 mm
Roll Core Diameter
19 mm, 34.9 mm
Media Feeders
1 x manual - 1 roll - Roll (11.2 cm)
1 x RS-232 - 14 pin DIN , 1 x USB - mini-USB Type B , 1 x docking
Belt clip, shoulder strap
Water resistant, dust resistant, drop resistant, built-in battery charger
CSA, UL, TUV, EN 60950, EN55024, EN55022 Class B, FCC Part 15 B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-5, EN55024 Class B, IEC 60529 IP43, VCCI Class B
Lithium Ion
Required Qty
1
Included
1
5000 mAh
Software Included
Drivers & Utilities, Link-OS
Limited warranty - 1 year , Limited warranty - printhead - 6 months
-20 °C
50 °C
10 - 90% (non-condensing)
16.5 cm
8.25 cm
18.7 cm
1.1 kg
Scroll to top
