BT.com
Wishlist
Zebra LS3578-FZ Barcode Scanner
Delivery
Standard Due date unavailable
Designed to meet the challenges of harsh manufacturing environments, the Symbol LS3578-FZ features fuzzy logic technology which allows first pass reads of nearly any 1D bar code, even when the bar code is dirty or damaged.
Reliable and secure wireless data transmission between the scanner and host is guaranteed with integrated Bluetooth, while the 150 ft. (45 m) range allows operators to move freely without being restricted by a cord. A rugged, drop-resistant design and a sealed housing provide reliability with less accident-related equipment failure and downtime.
Symbol LS3578-FZ - barcode scanner
Barcode scanner - portable - Bluetooth - decoded
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Scan Speed
36 scan / sec
Wireless
Wireless Connectivity
Bluetooth
1 x Lithium Ion
12.3 cm x 7.4 cm x 18.7 cm
414 g
3 years warranty
Yellow, twilight black
Barcode
Interface Type
Bluetooth
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Speed
36 scan / sec
Skew (Degrees)
50
Pitch (Degrees)
65
Print Contrast Signal (PCS)
25%
Decode Capability
Code 93, Code 39, UCC/EAN-128, IATA, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8 , EAN/JAN-13 , Discrete 2 of 5, Codabar, Code 128, Code 11, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Bluetooth
1 x USB
1 x USB cable - 2.1 m
VCCI, EN 61000-3-2, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, Bluetooth Class 2, IEC 60601-1-2, IEC 60529 IP65, ICES-003 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, OET 65 C, MITI, RSS-102, EMC, RoHS, IEC 825-1, FCC CFR21 Part 1040, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, CSA C22.2 No. 60950-1-07, IEC 60825-1
Power adapter - external
1 x Lithium Ion
12.3 cm
7.4 cm
18.7 cm
414 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
-20 °C
50 °C
5 - 95%
Drop Specification
2 m to concrete
Scroll to top
