BT.com
Wishlist
Zebra LP2824  Direct Thermal Label Printer
Zebra LP2824 Direct Thermal Label...
£262.66
£262.66
Add to wishlist
Delivery
Standard Due date unavailable
The ultra-compact direct thermal LP 2824 Plus bar code label printer brings powerful performance to applications requiring a space-saving printer and media widths of 2.2 inches/56 mm or less. It includes a 32-bit RISC processor for faster formatting and first label out, an auto-sensing serial port, and co-resident EPL and ZPL programming languages.
The LP 2824 Plus is easy to use with an OpenAccess design and clear media window for simple media loading and monitoring, color-coded user-guide touch points, and instant reset button. Serial, Parallel, and USB interfaces, plus networking option, ensure easy system integration for a wide range of applications.
Zebra LP 2824 Plus - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.2 kg
Max Media Size
Roll (6 cm)
Max Media Size (Custom)
60 mm
Print Speed
Up to 102 mm/sec - max speed
Max Resolution (B&W)
203 dpi
LAN
RAM Installed (Max)
8 MB
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Code 128B, Code 128C, German Post, MSI-3, Code 128A, GS1 DataBar Omnidirectional
Media Type
Labels, continuous forms, perforated thermal paper, receipt paper, linerless labels, fanfold paper, tag stock
Print server - Ethernet, Fast Ethernet
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
11.1 cm x 21.6 cm x 17.1 cm
Printer Type
Printer
Print Speed
Up to 102 mm/sec - max speed - 203 dpi
Wired
LAN
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
8 MB
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (6 cm)
60 mm
Media Sizes
Roll (6 cm)
Max Printing Width
56 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (6 cm)
Print server
1 x LAN - RJ-45
UL, VCCI, C-Tick, NOM, FCC, IRAM
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, ZebraDesigner
5 °C
41 °C
10 - 90%
11.1 cm
21.6 cm
17.1 cm
1.2 kg
Weight (Shipping)
2.4 kg
Scroll to top
