BT.com
Wishlist
Zebra LI4278 BT USB 7FT CBL IMG
£159.62
More than 50 in stock
£159.62
Add to wishlist
Delivery
Standard 1-3 working days
The LI4278 takes 1-D barcode scanning to the next level, allowing workers to scan faster and farther as they can capture virtually any 1-D barcode. Built for all day and everyday use, the LI4278 offers cordless freedom with Bluetooth compatibility. It also offers better encryption for improved security and better overall wireless performance.
Superior battery power management delivers the largest number of scans per battery charge to support scan intensive applications. You can use it in dusty and wet environments and it can survive a 6 foot/1.8 m drop.
Motorola LI4278 - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 - decoded
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Scan Speed
547 scan / sec
Wireless
Wireless Connectivity
Bluetooth 2.1
7 cm x 18.6 cm x 9.8 cm
224 g
3 years warranty
Cash register white
Barcode
Interface Type
Bluetooth 2.1
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Light Source Wave Length
617 nm
Scan Mode
Single-pass
Scan Speed
547 scan / sec
Max Working Distance
6 m
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, NW-7, IATA, ISBN, RSS Code, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, ITF, IATA 2 of 5, UPC-E1, GS1 DataBar-14, Code 39 Trioptic, GS1 DataBar Expanded, GS1 DataBar Limited
TTL Decoding
Decoded
Wireless
Triggered
Bluetooth 2.1
1 x USB
Cradle
1 x USB cable - external - 2.1 m
IEC 60601-1-2, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
Software
Software Included
Drivers & Utilities
7 cm
18.6 cm
9.8 cm
224 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
50 °C
5 - 85% (non-condensing)
Drop Specification
1.8 m to concrete
Scroll to top
