BT.com
Wishlist
Zebra G-Series GK420d Mono Direct Thermal Label Printer
Zebra G-Series GK420d Mono Direct...
£218.07
Hurry, only 3 left in stock!
£218.07
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Zebra GK420d direct thermal printer offers the best value in a basic desktop printer, featuring a fast 5 inches per second print speed to meet your low to medium volume printing requirements. The GK420d has a sleek and compact design, boasts the smallest footprint in a 4-inch desktop printer, and supports a variety of applications and industries.
The GK420d comes standard with EPL and ZPL programming languages, and dual connectivity (USB, serial) for easy integration into existing systems. For additional flexibility, 10/100 internal Ethernet is also available. Well-suited to any industry, the reliable GK420d desktop printer is a smart investment that's always a perfect fit.
Zebra GK Series GK420d - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.4 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 127 mm/sec - max speed
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Continuous forms, fanfold paper, tag stock
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
17.1 cm x 20.9 cm x 15.2 cm
Printer Type
Printer
Print Speed
Wired
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (10.8cm)
Max Printing Width
104 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 12.7 mm, 37.1 mm
Media Feeders
1 x manual - Roll (10.8cm)
1 x parallel / serial: - RS-232 - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
TUV, VCCI, C-Tick, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15, IRAM
AC 120/230 V
Frequency Required
50/60 Hz
5 °C
41 °C
10 - 90% (non-condensing)
17.1 cm
20.9 cm
15.2 cm
1.4 kg
Weight (Shipping)
3.2 kg
Scroll to top
