BT.com
Wishlist
Zebra DS3608-SR USB Kit Rugged Green Vibration
Zebra DS3608-SR USB Kit Rugged...
£280.69
Hurry, only 2 left in stock!
£280.69
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Marketing description is not available.
Symbol Digital Scanner DS3608-SR - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Wired
7.6 cm x 13.2 cm x 18.5 cm
305 g
3 years warranty
Black, green
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Max Working Distance
35 cm
Skew (Degrees)
50
Pitch (Degrees)
60
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, NW-7, IATA, RSS Code, QR code, MaxiCode, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8 , EAN/JAN-13 , Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet , PDF417, MSI-Plessey, Data Matrix, PLANET, Australian Post, Japanese Post, Code 128 Full ASCII, Code 39 Trioptic, Dutch Post, UK Post
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS), Two-Position Smart Focus, rugged
1 x USB
1 x USB cable - external
EN 60950, IEC950, UL 1950, IEC 60529 IP65, ICES-003 Class B, FCC Part 15 B, EMC, RoHS, CSA C22.2 No. 950
7.6 cm
13.2 cm
18.5 cm
305 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
-30 °C
50 °C
5 - 95% (non-condensing)
Scroll to top
