Click to visit BT.com
BT.com
Wishlist
Zalman ZM K400G Gaming Keyboard
3.0*
Quicklinx: 8H80WS00
Mfr#: ZM-K400G
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£18.74
Marketing description is not available.
ZALMAN ZM K400G - keyboard
Keyboard
USB
Layout
QWERTY
Keys Qty
118
Hot Keys Qty
12
Hot Keys Function
Multimedia, volume, mute, lock computer, play/pause, stop, media player
Blue LEDs, laser engraved printing keys, red LEDs, adjustable brightness, individual key LED backlight, height-adjustable feet, 12 programmable keys, zinc-plated cable
46.3 cm x 19.1 cm x 3 cm
700 g
Keyboard
USB
Input Device
Keys Qty
118
Hot Keys Qty
12
Hot Keys Function
Layout
QWERTY
46.3 cm
19.1 cm
3 cm
700 g
1 x USB cable - 1.5 m
MTBF
10,000,000 incidents
Zalman ZM K400G Gaming Keyboard Bundle deal on Zalman ZM K400G Gaming Keyboard
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£28.73
Customer reviews
Write a review for the Zalman ZM K400G Gaming Keyboard here!
Not a bad Keyboard
Reviewed by Robbie. Review Posted 23/04/2014
I bought this in mind that I would soon get a keypad and wouldn't need a flash mechanical keyboard.
I have been using it for some heavy gaming for the past few days now from arcade games to shooters and I have been pleasantly surprised by the quality for an item of this price. It fells comfortable and they keys have a nice resistance and spring return.
The only down side I have found is the quality of the plastic that the main body is constructed from, although it does have a nice antithetic finish when you touch it, it does feel a bit "cheap" but that's exactly what this is, a cheap keyboard. It is also vey lightweight which may appeal to some but I like my things to feel a bit more substantial.
All in all I am happy with my purchase and I would recommend it to a friend who like me is getting on their feet with a first pc build.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
Exactly the same as a AJAZZ £5 keyboard
Reviewed by Daz. Review Posted 14/07/2014
A quick look inside and its the same product near enough just £10 more than an ajazz board
Sometimes when gaming button presses dont register on Battlefield , like W for walk forward and it doesnt (not always but it shouldnt happen at all), dont know if this is just an issue with cheap membrain type boards but it really annoys me , what really annoys me is the build , this is built cheap as possible and is not a gaming board (just because its backlit) like i said buttons dont register when your using more than a couple whitch is dog s*
It works and for typing its about the same as any other board made like this.
  • Overall 3*
  • Ease of use 2*
  • Value for money 2*
Can't see the keys!
Reviewed by Tim Oliver. Review Posted 25/01/2016
Hi, this keyboard if nice to type with BUT... I brought this keyboard as I needed to see the keys in low light, trouble is the light is way to dim! the keys are completely see through making it worse then a normal keyboard to see in low light. Totally useless in a low light gaming environment. My Dell laptop has a backlit keyboard which works a charm. Will be returning this keyboard.
  • Overall 2*
  • Ease of use 2*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 8H80 033411
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £11.05
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Keyboard
Colour: Black
Compatibility: PC
Cherry MX Switch Colour: [N/A]
Brand: Zalman
Stock Status: Used Stock
Price Range Inc VAT: 0 - 50
