BT.com
Wishlist
Zalman Z5 Plus ATX Mid Tower PC Case
Delivery
Standard Due date unavailable
  • Up to 5 fans can be mounted with standard-equipped 120? front LED fan and back 120? fan. (extra 120? top LED fan standard-equipped on Z5 Plus)
  • Supports bottom PSU installation for effective cooling of PSU and inner space of case
  • Aerodynamically designed front/top vents provide cool air into the system.
  • Luxurious interior with black coating finishing touch.
  • USB ports, audio socket, power and rest buttons set on the top for user convenience. (USB 3.0 & fan controller available only on Z5 Plus)
  • Place smart phone, external hard drive on the stand next to the USB port for convenient charging and connection.
  • Tube apertures are provided at the rear of the case for convenient water cooling set-up and maintenance.
  • Dust filters on the bottom side prevent dust from entering.
  • Safe edge molding for safer installing environment.
  • Without the side guide 330? high performance VGA card can be installed.
  • Side Acryl Tuning is provided for users to view the interior of gaming system.
  • Anti-slip rubber at the bottom of the case and the PSU helps to eliminate vibration sound.
  • Provides spacious interior with 7 PCI extension slots.
  • 3 in1 Adapter Tray is provided for installing FDD / 3.5' HDD / 2.5' HDD / SSD.
  • Space is provided on the bottom of the case for additional installation of 2.5' HDD/SSD.
  • Separate aperture for CPU cooler is provided for convenient CPU cooler installation without having to remove motherboard from case.
Specification
  • Enclosure Type ATX Mid Tower
  • Dimensions 205(W) x 460(H) x 490(D)?
  • Weight 6.5kg
  • Material Plastic, Steel
  • Motherboard Compatibility Standard ATX / Micro ATX
  • Power Supply Compatibility Standard ATX / ATX12V
  • VGA Compatibility Full Size (up to 330?)
  • Expansion Slot 7
  • Drive Bays 5.25' External Bay x 3
  • 3.5' Internal Bay x 3
  • 2.5' Internal Bay x 2
  • 5.25'/3.5'/2.5' 1 (3 in 1)
  • Cooling Components Front 120? Blue LED Fan x 1 (Fan included)
  • Top 120? Blue LED Fan x 2 (1 Fan included, 1 optional)
  • Rear 120? Fan x 1 (Fan included)
  • Bottom 120? Fan Vent x 1 (Fan optional)
  • Fan Controller Yes (2 channel)
  • Side Acylic Tuning Yes
  • I/O Ports Microphone x 1, Headphones x 1, USB 2.0 x 2, USB 3.0 x 1
  • Color Black
Zalman Z5 PLUS - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
1 x microphone , 1 x headphones , 2 x USB 2.0 , 1 x USB 3.0
Supported Motherboards
ATX, microATX
System Cabinet Features
Windowed side panel, floor dust filter, water cooling holes
No power supply
Specification Compliance
ATX
20.5 cm x 49 cm x 46 cm
6.5 kg
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
3
Front Accessible Bays Qty
7
Cooling System
Front: 120 mm fan x 1 / blue LED , Top: 120 mm fan x 1 , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 1 (total) / 1 (free) x front accessible - 2.5" / 3.5" shared
Expansion Slots
7 x Expansion Slot
1 x microphone - mini-jack , 1 x headphones - mini-jack , 2 x USB 2.0 , 1 x USB 3.0
Cable ties, 5.25" to 3.5" / 2.5" bay adapter, CPU 12V extension cable, HDD rubber slide rail
No power supply
20.5 cm
49 cm
46 cm
6.5 kg
Scroll to top
