BT.com
Wishlist
Zalman Z5 ATX Mid Tower PC Case
Delivery
Standard Due date unavailable
  • Up to 5 fans can be mounted with standard-equipped 120? front LED fan and back 120? fan.
  • Supports bottom PSU installation for effective cooling of PSU and inner space of case.
  • Aerodynamically designed front/top vents provide cool air into the system.
  • Luxurious interior with black coating finishing touch.
  • USB ports, audio socket, power and rest buttons set on the top for user convenience.
  • Place smart phone, external hard drive on the stand next to the USB port for convenient charging and connection.
  • Tube apertures are provided at the rear of the case for convenient water cooling set-up and maintenance.
  • Dust filters on the bottom side prevent dust from entering.
  • Without the side guide 330? high performance VGA card can be installed.
  • Safe edge molding for safer installing environment.
  • Easily install HDD without any tool.
  • Anti-slip rubber at the bottom of the case and the PSU helps to eliminate vibration sound.
  • Provides spacious interior with 7 PCI extension slots.
  • 3 in 1 Adapter Tray is provided for installing FDD / 3.5' HDD / 2.5' HDD/SSD.
  • Space is provided on the bottom of the case for additional installation of 2.5' HDD/SSD.
  • Separate aperture for CPU cooler is provided for convenient CPU cooler installation without having to remove motherboard from case.
  • Case Type ATX Mid Tower
  • Dimensions 205(W) x 460(H) x 490(D)?
  • Weight 6.5kg
  • Material Plastic, Steel
  • Motherboards Standard ATX / Micro ATX
  • Power Supply Compatibility Standard ATX / ATX12V
  • VGA Compatibility Full Size (up to 330?)
  • Expansion Slots 7
  • Drive Bays 5.25' External Bay x 3
  • 3.5' Internal Bay x 3
  • 2.5' Internal Bay x 2
  • 5.25'/3.5'/2.5' 1 (3 in 1)
  • Cooling Component Front 120? Blue LED Fan x 1 (Fan included)
  • Top 120? Fan Vent x 2 (Fan optional)
  • Rear 120? Fan x 1 (Fan included)
  • Bottom 120? Fan Vent x 1 (Fan optional)
  • I/O Ports Microphone x 1, Headphones x 1, USB 2.0 x 2
  • Color Black
Zalman Z5 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
1 x microphone , 1 x headphones , 2 x USB 2.0
Supported Motherboards
ATX, microATX
System Cabinet Features
Floor dust filter, water cooling holes
No power supply
Specification Compliance
ATX12V
20.5 cm x 49 cm x 46 cm
6.5 kg
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX12V
Internal Bays Qty
5
Front Accessible Bays Qty
3
Cooling System
Front: 120 mm fan x 1 / blue LED , Top: 120 mm fan mount x 2 , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
1 x microphone - mini-jack , 1 x headphones - mini-jack , 2 x USB 2.0
Cable ties, 5.25" to 3.5" / 2.5" bay adapter, CPU 12V extension cable, HDD rubber slide rail
No power supply
20.5 cm
49 cm
46 cm
6.5 kg
Scroll to top
