Click to visit BT.com
BT.com
Wishlist
Zalman Ultra Quiet Low Profile CPU Cooler
5.0*
Quicklinx: 78WBWS00
Mfr#: CNPS8000B
The CPU cooler's height is designed to be installed in ATX case as well as slim or LP cases. The cooler installation clip and bolt are designed as one-piece, making installation convenient, and the patented back plate prevents flexing of the motherboard. The high performance super thermal grease ZM-STG2M maximizes heat transfer from the CPU to the base of CNPS8000A for intensified cooling performance.
  • Powerful cooling performance
    Four heatpipes and aluminum fins are designed for maximum cooling while switching noise free, down-blowing fan minimizes noise and cools not only the CPU but also provides powerful peripheral cooling.
  • Slim profile
  • Easy installation
  • High performance super thermal grease
ZALMAN CNPS 8000A - processor cooler
Processor cooler
Package Content
Thermal paste, cable, fan speed controller
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3
Heatsink Material
Aluminium with copper base
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1400-2600 rpm
Noise Level
20 dBA
Power Connector
3-pin plug
Heat pipe technology
10.8 cm x 10.8 cm x 6.6 cm
330 g
Processor cooler
Package Content
10.8 cm
10.8 cm
6.6 cm
330 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core i7 Extreme Edition - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core 2 Quad - all speeds , Core 2 Duo - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Pentium D - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Phenom II - all speeds , Athlon II - all speeds , Dual-Core Opteron - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Athlon - all speeds , Sempron - all speeds
Heatsink Material
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1400-2600 rpm
Noise Level
20 dBA
Power Connector
3-pin plug
Customer reviews
Write a review for the Zalman Ultra Quiet Low Profile CPU Cooler here!
Best Cooler
Reviewed by Anonymous Review Posted 28/02/2012
very quiet and compact, I hardly notice the noise coming from this cooler.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
