Click to visit BT.com
BT.com
Wishlist
Zalman Silent CPU Cooler with Pure Copper & 92mm Fan
Quicklinx: 8278WS00
Mfr#: CNPS7000C-ALCU
Silent CPU cooler built with pure copper and pure aluminum for enhanced performance and optimized compatibility design.
Compatible CPUs
  • Pentium 4 Prescott, Pentium 4 Cedar Mill, Pentium 4, Celeron D, Core 2 Duo, Core 2 Quad, Pentium Dual Core, Core i7, Core i5, Core i3, Sempron, Athlon, Athlon FX, Opteron, Phenom, Athlon X2, Phenom II, Athlon II, Llano, Zambezi
  • Does not generate noise or vibration in Silent Mode.
  • Pure copper and pure aluminum base materials ensure excellent heat dissipation.
  • Compatible with single and dual core CPUs for Intel Socket 1155/1156/775 and AMD Sockets FM1/AM3+/AM3/AM2+/AM2/754/939/940.
  • 92mm fan inside the heatsink maximizes airflow.
  • Adjustable fan speed controller(FAN MATE 2) enables control of noise and fan performance.
  • Dimensions 109(L) x 107(W) x 63(H) mm
  • Weight 750g
  • Base Material Pure Copper & Pure Aluminum
  • Dissipation Area 2,890?
Fan
  • Bearing Type 2 Ball-Bearing
  • Speed(1) 1,350rpm ± 10% ~ 2,400rpm ± 10%
  • Noise Level(2) 17.0dBA ± 10% ~ 24.0dBA ± 10%
Includes
  • Common Components: Cooler (CNPS7000C-AlCu), Clip Support, Clip Support Fixing Bolts, Washers, Nuts, Thermal Grease, FAN MATE 2, FAN MATE 2 Cable, Double-Sided Tape, User's Manual
  • Intel Components: Intel Clip, Intel Clip Fixing Bolts
  • AMD Components: AMD Clip, AMD Clip Lever
ZALMAN CNPS 7000C-AlCu - processor cooler
Processor cooler
Package Content
Fan controller cable, fan controller (FAN MATE 2), thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium and copper
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1350-2400 rpm
Power Connector
3-pin plug
Variable fan speed, manual fan speed control
10.9 cm x 10.7 cm x 6.3 cm
Manual fan speed control
Processor cooler
Package Content
10.9 cm
10.7 cm
6.3 cm
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo - all speeds , Pentium 4 , Celeron D - all speeds , Athlon 64 - all speeds , Athlon 64 FX , Athlon 64 X2 , Sempron - all speeds
Heatsink Material
Heatsink Dimensions
109 mm x 107 mm x 63 mm
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1350-2400 rpm
Power Connector
3-pin plug
Mounting Kit
Included
Sound Emission
17 dBA
