Click to visit BT.com
BT.com
Wishlist
Zalman Optical Gaming Mouse M300 (USB/2500dpi/7 Buttons)
Quicklinx: 8B7LWS00
Mfr#: ZM-M300
High precision, low cost, 7 button gaming mouse
The ZM-M300 optical gaming mouse from Zalman offers more precise movement detection over standard mice thanks to its state-of-the-art Avago 5050 single chip navigation sensor which has been specifically designed for use in computer mice where accuracy is essential.
  • Avago 5050 high precision optical sensor
  • Adjustable resolution from 625 - 2500 DPI
  • High Frame rate of 4500 FPS
  • LED DPI indicator
  • Ergonomic design for a comfortable grip
  • 7 Buttons, one with auto-fire for gaming
  • 1.5M Cable length
The ergonomic design means that the ZM-M300 fits nicely into the palm of your hand and a matt finish on the side of the mouse gives a slightly textured feel for an improved grip. The two buttons on the side have a springy yet firm feel and sit nicely under the thumb. The two small buttons at the side of the left mouse button are the DPI selector and auto fire buttons.
One feature seldom found on mice is a Ferrite Bead which is moulded into the end of the cable. This is a passive electric component used to suppress high frequency noise/interference (generated by most electronic components) from reaching the rest of the system.
ZALMAN ZM-M300 - mouse - USB
Mouse
Wired - USB
6.5 cm x 13.2 cm x 4.2 cm
78 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
2500 dpi
Performance
4500 fps, realtime sensitivity switching 625 - 2500 dpi
Auto fire, scrolling wheel
1 x USB cable - integrated - 1.5 m
Mouse
6.5 cm
13.2 cm
4.2 cm
78 g
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
2500 dpi
Performance
1 x USB - 4 pin USB Type A
