Click to visit BT.com
BT.com
Wishlist
Zalman Heatpipe CPU cooler with 92mm blue LED fan
5.0*
Quicklinx: 4C89WS00
Mfr#: CNPS9500ALED
Supports AM2
Despite the fact that computers have become commonplace at home and at workplaces for a long time, true user friendliness of the computers is still a long shot. Zalman Tech strives to make that goal a closer reality through extensive research and development of its products and will continue to put efforts to creating more enhanced levels of user friendliness in computing.
PRODUCT FEATURES:
100% copper heatsink with aerodynamically optimized 'tunnel' design for maximum cooling efficiency; Innovative and patented, curved heatpipe design for a heat transfer capacity of up to 6 heatpipes with the use of just 3; Optimized heatsink layout for maximum cooling efficiency with minimal materials; 0.2mm ultra-slim fins for minimized weight and reduced airflow resistance; Ultra quiet CNPS 92mm opaque fan with blue LEDs; Aerodynamically optimized heatsink for smoother airflow and minimal noise.
ZALMAN CNPS9500A LED - processor cooler
Processor cooler
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Copper
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1350-2600 rpm
Heat pipe technology, manual fan speed control
11.2 cm x 8.5 cm x 12.5 cm
0.5 kg
Processor cooler
11.2 cm
8.5 cm
12.5 cm
0.5 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Celeron , Celeron D , Pentium 4 , Pentium D , Core 2 Duo , Core 2 Quad , Core 2 Extreme , Sempron , Athlon 64 , Athlon 64 X2 , Athlon 64 FX , Opteron , Dual-Core Opteron
Heatsink Material
Copper
Thermal Resistance
0.12 °C/W
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
1350-2600 rpm
Mounting Kit
Included
Sound Emission
18 dB
Customer reviews
Write a review for the Zalman Heatpipe CPU cooler with 92mm blue LED fan here!
Great fan, requires effort
Reviewed by Bob. Review Posted 06/04/2009
Great fan, quiet and excellent cooling (80 to 40 under max stress on my current core)
however
Make sure you have this fan before you put together your pc, else you will be taking it apart again.
It comes with a base plate that has to be attached under the motherboard, but this make's it tight and secure (unlike these push in clips on the stock I had, which are pretty damn useless)
  • Overall 5*
  • Ease of use 3*
  • Value for money 5*
Good fan
Reviewed by Anonymous Review Posted 26/05/2008
Ordered the fan on friday evening, and it arrived the next morning (credit to BT for consistent brilliant service). Installation of the fan can be tricky, and i wouldn't recommend it for people who are not familiar with removing components such as the motherboard and graphics cards from the case. However, the fan works wonderfully and is quieter on the lowest setting than the stock was at full power, and more efficient. Overall a great fan, reducing both my case and CPU temperature by about 12 degrees at both idle and load.
  • Overall 5*
  • Ease of use 1*
love this to bits
Reviewed by Chris. Review Posted 26/02/2009
it's an excellent cooler, if you have the patience to read the manual cover to cover you'll get there in the end, it took me an hour to install this on my board (my first ever Zalman cooler) but it was worth the effort.
cuts the temperatures achieved by the intel stock cooler in Half.
if your wanting to overclock and ya don't fancy water, get this.
  • Overall 5*
  • Ease of use 2*
Quiet and efficient!!
Reviewed by . Review Posted 08/08/2008
Great fan, very quiet and efficient, when you connect it forget about Fan Mate, your motherboard will do the job, it will speed up the fan if needed and slow it down, when the CPU is in idle mode!! Allows to overclock Phenom X4 9850 to 3.16 GHz, from standard 2.5GHz, I will try even more later this day!! The only thing I do not like about this product is that led, when you leave a computer overnight in your room is bright like during the day, and you can not disconnect it without cutting some wires!!
  • Overall 5*
  • Ease of use 5*
Great fan
Reviewed by Darren. Review Posted 18/04/2007
This is a fantastic fan, probably the best cpu cooling this side of water cooling.
having said that, the fan's installation is a complete and utter pig. the copper blades are sharp and i actually cut myself a couple of time during the install!
It's basically an extremely good fan though and it runs very quiet.
  • Overall 5*
  • Ease of use 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
