Click to visit BT.com
BT.com
Wishlist
Zalman CNPS8900 Quiet Ultra Quiet Slim CPU Cooler
Quicklinx: 861NWS00
Mfr#: CNPS8900 QUIET
Two heatpipes and aluminum fins are designed for maximum cooling while switching noise free, down-blowing 110 mm fan minimizes noise and cools not only the CPU but also provides powerful peripheral cooling.
DTH technology transfers the CPU's heat directly to heatpipes, thereby minimizing heat resistance and maximizing cooling performance.
Compatible with Intel LGA1366/1155/1156/775 and AMD FM1/AM3+/AM3/AM2+/AM2
ZALMAN CNPS 8900 Quiet - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2
Heatsink Material
Aluminium with copper base
Fan Diameter
110 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1000-1500 rpm
Noise Level
19 - 25 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Heat-pipe Direct Touch (H.D.T.) Technology, Pulse-width modulation (PWM) support, 2 copper heatpipes
12 cm x 12 cm x 6 cm
400 g
Processor cooler
Package Content
Thermal paste
12 cm
12 cm
6 cm
400 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core i7 Extreme Edition - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core 2 Quad - all speeds , Core 2 Duo - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Pentium D - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Phenom II - all speeds , Athlon II - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Athlon - all speeds , Sempron - all speeds , Dual-Core Opteron - all speeds , Opteron - all speeds , AMD A Series - all speeds , FX Series - all speeds
Heatsink Material
Heatsink Dimensions
120 mm x 120 mm x 60 mm
Fan Diameter
110 mm
Fan Bearing
Long Life Bearing
Rotation Speed
1000-1500 rpm
Noise Level
19 - 25 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
