Click to visit BT.com
BT.com
Wishlist
Zalman CNPS2X Low Profile CPU Cooler
2.0*
Quicklinx: 9071WS00
Mfr#: CNPS2X
Tiny 120 W class cooler applied the DTH, 'S' bending technology and the optimal heat dissipation design. Emit the air straight from the fan to the mother board through down blowing design, it cools down not only the CPU but also the components around it.
Direct Touch Heatpipe (DTH) Base technology transfers the CPU's heat directly to heatpipes, thereby minimizing heat resistance and maximizing cooling performance.
Compatible with Intel 1150/1156/1155/775 and AMD FM2/FM1/AM3+/AM3/AM2+/AM2
ZALMAN CNPS 2X - processor
Package Content
Thermal paste
8.4 cm
8.4 cm
2.7 cm
83 g
Heatsink & Fan
Compatible With
Socket 775, Socket 1156, Socket AM2, Socket AM2+, Socket AM3, Socket 1155, Socket AM3+, Socket FM1, Socket FM2, Socket 1150
Processor Compatibility
Core i7 Extreme Edition - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core 2 Quad - all speeds , Core 2 Duo - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Pentium D - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Phenom II - all speeds , Athlon II - all speeds , Opteron - all speeds , Phenom - all speeds , Athlon 64 FX - all speeds , Athlon X2 - all speeds , Athlon - all speeds , Sempron - all speeds
Heatsink Material
Aluminium and copper
Fan Bearing
Long Life Bearing
Rotation Speed
1500-2600 rpm
Noise Level
17.4 - 22.7 dBA
Rated Voltage
12 V
Heat pipe technology, Pulse-width modulation (PWM) support
Customer reviews
Write a review for the Zalman CNPS2X Low Profile CPU Cooler here!
Be careful when buying, Test board before fitting!!
Reviewed by Anonymous Review Posted 13/10/2014
My personal experience with this cooler. The cooler has a back-plate attachment behind the CPU Socket which is affixed with double sided sticky tape so once the CPU socket back-plate is affixed it is a nightmare to remove. I did not test my motherboard prior to fitting the fan and the motherboard turned out to be faulty but due to the customization of the board with the original back-plate removed due to fitting one of these I was unable to return it to BT. Ended up selling the board and fan on Ebay for £6 as a combo. So my warning to anyone who purchases one of these is to test your motherboard before fitting one of these else you may have problems returning a faulty board.
  • Overall 2*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
